Old 17th June 2007, 09:25 PM   (permalink)
Originally Posted by kid-kv
what if i took out the 4060 and used a 555 timer to get the 4hz would that work
the 22pf caps will not show up on my dmm as 0.022 nf
the display now shows 85hz to 100hz and did the pic of the board help??
Kid-kv
You could try this as a temporary experiment, but it is unacceptable as a permanent change because the oscillation frequency of the 555 will not be accurate or stable enough for good performance.
Before doing that, I would want to check that the counter portion of the circuit is working ok, that is, that U1 and U2 and the display circuits are all fine. If you can force U1 pin 10 and pin 13 low, then U1 should count up without stopping or resetting and continue to do so as long as you feed it an input at pin12. If your input is a low enough frequency then you should easily be able to see the displayed count increase in a readable way. One way to make the input signal toggle slowly is to connect up a button or toggle switch temporarily to ground and add a pullup resistor at the input. Pushing the button will provide a small number of pulses depending on how much switch bounce there is and so you should see the counter advance a few units.
If the counter is working fine, then we can turn our attention back to the timebase of U3 and U4. I would not suspect that the 4060 is blown. This is a common mistake made by novices, assuming that because things aren't working right the ICs are blown. They usually are not and usually the problem is a design mistake or a hookup mistake. I gather you don't have an oscilloscope handy. This is too bad as it would be quite helpful now.
The key is getting our oscillator in the 4060 to work right and its hard to check that without a scope. Have you already tried more than one crystal?
On the schematic, there are capacitors labelled C5, C6, C7, C8, and C9. Your board does not appear to include these. Why did you leave them out? These are important and should be placed very near each IC. You can add these by tacking them on to the underside of the board directly to the appropriate IC pads.
Of course it is critical that you be sure that your crystal capacitors be 22 pF, not 22nF or some other value.
The pic of the board is helpful, although your choice of colours is making it difficult. I would have recommended a white background, blue for IC outlines and bright green for all copper pads and traces. Labels are best left red, brown, violet or blue.
Are you available for skype chat?
RadioRon
RadioRon is offline
Old 17th June 2007, 10:18 PM   (permalink)
hi, RadioRon
I did look over the board and its ok..
the board is a custom pcb all leads are short that i did kept in mind when i did it..
will be back with more when done
Kid-kv
Hmm, if the board is supposed to match the schematic, then I find these mistakes:
- C5,6, 7, 8, 9 are missing
- U4 pins 2,3,4,10,11,12 are grounded while on the schematic they are floating. U4A and U4B will not toggle in this case are so are not functioning. For these to function, pins 2,3,4,15, 10, 11, 12 and 14 should all be pulled to +5V (or can be left floating, but its not as reliable).
- your layout includes connections to U5 pins 11 and 13 which are not shown in the schematic. Happily, these connections repair a problem of incorrect hookup of the U5B which is a good thing, so in this case the layout is good and the schematic is bad. But why are they different?
As for the board layout, your circuit is vulnerable to noise problems due to the way you have connected up +5V and GND. It would have been better to run your ground traces in a hub-and-spokes configuration, where the hub of the ground is at the connector J1 and all the IC grounds return directly to this point or to a common bus bar. We use ground planes specifically for this purpose. Similarly, it is often better to distribute your +5V from a bus bar or from a single point to all ICs. You have connected +5 and GND in a daisy chain which is typically not so good. I wouldn't worry about it too much in this case for one exception. Since the CMOS ICs draw relatively small amounts of current when switching you may not suffer much trouble (once you add the missing bypass capacitors that is). However, the 4511 and the drive transistors are passing a lot of current (approx 15mA per segment of display) and they are being switched on and off at a rapid rate (the mux rate). This rapid switching of high currents will generate a noise voltage on +5 and ground that will be seen by the other ICs. This is a particular problem that you might want to fix. You should run the +5V to U2 all the way back to J1 on a separate wire from the other ICs, and run the ground from Q1,2,3 back to J1 separate from the other grounds. Bypass capacitors (C5..9 in the schematic) are critical to helping avoid problems due to this error.
RadioRon
RadioRon is offline
Old 17th June 2007, 11:24 PM   (permalink)
On further examination of the pcb:
- I would have routed the connections to the two capacitors on the crystal a bit differently. In your layout, each capacitor's ground connection is long, adding some inductive reactance to the connection. Normally you should route these capacitor grounds directly back to the IC ground pin.
- I would not connect those copper pads around your mounting holes to your circuit ground. This creates a second path for ground currents to flow if you use a metal chassis and metal standoffs, which in principle can be a problem. You would normally want to insure that ground currents flow only through J1 to avoid ground loops. In your case it may not make a difference, but something to think about in future.
- exactly how have you modified the connection to the 4060 pin 12?
You know, I've spent a few minutes studying the logic of this counter and it doesn't make sense exactly. The time base appears to be designed to provide a gate time of 0.5 seconds minus the width of the one shot pulse which would be around about 5 mSec. This seems like sloppy design. This also means that the display will show approximately half the frequency in Hz. Why?
Normally a counter allows a gate time of precisely 1 second in order for the value in Hz to be displayed, and normally the reset logic is done outside of the gate time in such a way that you don't see it counting up during the gate time, you just see the latched result. This counter allows you to see it counting up. Exactly what is this counter supposed to be telling you about the TIG Welder?
RadioRon
RadioRon is offline
Old 18th June 2007, 05:01 AM   (permalink)
hi, it does count up. And it does stop. I do think that it is the caps c2, c3.
i did use a oscilloscope and all looks good HP 1200A 500khz.
Have you already tried more than one crystal? yes watch crystal..
at first the crystal would not oscillat then when i put the scope on it then it would oscillat then i found out that it needed a resistor...
pins 2,3,4,15, 10, 11, 12 and 14 should all be pulled to +5V ok will do this with them to gnd it would stop at 000hz..
capacitors labelled C5, C6, C7, C8, and C9 You can add these by tacking them on to the underside of the board directly to the appropriate IC pads. i did that.
My best guest is that it would be the board....i say this becoz when i put my hand near it it flips out.
this is to show what frq that you are at when welding alu, sheet metal. helps make the arc more stable.
Are you available for skype chat? no =-(
Kid-kv
kid-kv is offline
Old 19th June 2007, 03:31 AM   (permalink)
Thumbs up
HI, RadioRon
I did some of what you said and now its off by 4hz..
I put a dmm with a square wave out of 50hz and it gave me 54hz
Thanks for the help
now i can fine tune the rest of the circuit
thanks
will come back when i need more help and will try to help out
kid-kv
kid-kv is offline
Old 21st June 2007, 03:15 AM   (permalink)
The schematic i did not draw it up the board that is in pdf was not right so i had
to redo it in eagle becoz you could not see whear the chips whent so does that
help as to why they are different..
kid-kv
thanks again
kid-kv is offline
PIC16F628A Reset? marting Micro Controllers 18 5th December 2008 09:31 PM
Problem with LCD code? spondootre Micro Controllers 15 29th April 2008 10:15 AM
microchip application A590 /display is ok now prosound90 Micro Controllers 20 18th November 2006 10:44 PM
Display Driver for 16 * 16 matrix display pmphilip General Electronics Chat 2 4th January 2006 08:15 PM
