| I need to build a circuit to create a 5 volt peak to peak square wave, that is 5 volts high and 0 volts low. How can I add a 2.5V DC offset to one of the standard simple 555 timer oscillator circuits? The circuit will be operating around 500 khz (exact frequency doesn't matter). I wasn't sure if I put a Zener diode in the ground pin to the timer chip or I floated it above ground with a voltage divider if that would work. If this is not a workable idea, is there a circuit that I could build to feed the output of my function generator into that would allow me to add a voltage offset (can I do this with an opamp?) Thanks for any advice. Chris | |
| You can use an op-amp buffer circuit, except you connect the input that normally goes to ground to a resistive divider. Though, the op-amp supply has to be 7.5V or greater. | |
| hi chris, If you use a 7.5Vdc supply for the 555 and use a 2.5Vref[zener] from the 555 0v pin to the 'system' ground that should be OK, connect a cap across the 2.5VZ. You should use this 2.5V virtual ground [junction of the 555 and the 2.5VZ] as the ref ground for all the timing components on the 555 circuit. What are you going to drive with the 5Vsqrwave + 2.5v ?
__________________ Eric "Good enough is Perfect" PIC tutorials: Gramo's: www.digital-diy.net/ Bill's: www.blueroomelectronics.com/ | |
| Hi DK and Eric, I am testing a digital transceiver chip for a project and the datasheet said that it could be driven up to VCC (I am using 5 volts) but not to let the wave swing below -0.3V. I have a spare LM358 or two lying around so I will use this as my bias generator for the 555 timer circuit. Thanks again! Chris | |
| I don't see why you would need to?, running the 555 off the 5V supply it will output a rectangular wave from (roughly) 0V to 5V. | |
| 12v to 5v DC circuit help | lofar | Electronic Projects Design/Ideas/Reviews | 7 | 8th March 2007 10:56 PM |
| DC offset | whiz115 | General Electronics Chat | 26 | 2nd March 2007 03:19 AM |
| Timer Circuit needed | barkster101 | Electronic Projects Design/Ideas/Reviews | 4 | 24th February 2007 04:40 PM |
| timer circuit needed | n5oxp | Electronic Projects Design/Ideas/Reviews | 34 | 4th September 2003 11:03 PM |
| variable 5,10,15,20 minutes timer circuit | james | Electronic Projects Design/Ideas/Reviews | 3 | 24th October 2002 03:24 PM |
