Old 31st May 2007, 08:27 PM   (permalink)
Default DC OP amp Grounding
hi there everybody
browsed the forums for a while, but only recently registered my own account. First, great place, tons of info and invaluble expertise! I was hoping you all could help me with a little quandry of my own.
I noticed that another member was asking about power supplies to op amps, and now I have a similar question.
I would like to run an op amp off of a dc current from only one source, a battery. I found this on the internet and had a few questions about it.
http://instruct1.cit.cornell.edu/Cou...nglesupply.pdf
(figure 7 at the bottom of the doccument)
What they are trying to do is create a phantom ground for the op amp. Unfortunately I have no electrical engineering degree, only years of fooling around with electronics, so I am a bit uneducated.
I will be using the op amp to power a fet and I assume I will still use the output of the op amp directly into the base of the fet, however I do not understand why the output is grounded.
Also, how is it that there are grounds within this circuit if there is no ground? (hence one battery source) are these ground points different from other ones I may have from the input circuit? Are they just common connection points within this circuit?
Bassically I want to know how to use this effectively, I will have three stages in my circuit, an input, this op amp, and a fet. I want it all off of the same power source.
Thanks for takin a look.
Armagdn03 is offline
Old 31st May 2007, 10:37 PM   (permalink)
I think it is an error. It looks like a voltage follower to me and the output should not go to ground. The output voltage should be Vs/2 with the values shown.
k7elp60 is offline
Old 1st June 2007, 12:28 AM   (permalink)
that would make alot more sense, I mean I dont know alot, but from what I do know, I would think that grounding the output would complete the circuit, making it useless for the mosfet stage.
Old 1st June 2007, 12:38 AM   (permalink)
WAIT! maybe there is an error and maybe not I found another schematic...
http://www.analog.com/library/analog...iding/Fig1.gif
Here they have a resistor between the output and the ground, effectively creating a voltage drop / potential across it. This make sense to me to some degree, but how would I connect the mosfet stage to this, the only applications where I have seen something like this is where you connect aboce and below the resistor, but only one output goes to the mosfet..... so would you ground the emmiter of the mosfet and then connect the gate above the resistor?
oops, here is the diagram
Old 1st June 2007, 12:39 AM   (permalink)
also, what does BW1 and BW2 etc. stand for?
Old 1st June 2007, 02:57 AM   (permalink)
No professional, but I think you are thinking of the resistor load wrong, you dont connect above or below it for the mosfets, the whole mosfet stage IS the resistor. But i dont knwo what bw1 or bw2 etc. are. maybe someone else can fill in those holes.
Tortuga0303 is offline
Old 1st June 2007, 03:17 AM   (permalink)
The kid who drew that extremely confusing figure 7 schematic has the battery backwards. He is crazy to ground the positive supply and the output of the opamp. He has grounds all over the place.
Figure 7 is supposed to be a virtual ground circuit that is a very low impedance at half the supply voltage for biasing other opamps.
BW1 is a highpass filter in the negative feedback loop of the opamp.
BW2 is a lowpass filter at the input of the opamp.
The BW1 and BW2 are reversed in the two circuits. Very confusing.
audioguru is offline
Old 1st June 2007, 04:16 AM   (permalink)
wow, always makes learning a blast and a half....well scrap that then, what about this setup for using a battery and an op amp..
will this be a suitable circuit for driving a high power mosfet of a single supply?
Old 1st June 2007, 04:17 AM   (permalink)
wow, didnt even notice, but those are the same schematics, from two different sources....Can this be right?
Old 1st June 2007, 04:37 AM   (permalink)
The virtual ground opamp is for biasing other opamps, not for driving a Mosfet.
Old 1st June 2007, 05:47 AM   (permalink)
do you know of any websites that might have a schematic on how I would go about driving a power mosfet with a single power supply? I would like this to be able to be run on a marine set up, so only one lead acid battery is availible (could do two, but I would like it to be portable and transferable to other boats.)
Old 1st June 2007, 08:32 AM   (permalink)
The diagram shows a OPA being used to create a phantom ground, thats why the output of the OPA is grounded. By using this phantom ground in your system as the common ground reference, it effectively splits the single supply voltage into two, ie +V/2 and -V/2.
So if you had a single supply source of say, 12V, then with reference to the phantom ground [the grounded output of the OPA] you will have a +6V and a -6V for your other OPA's in the system.
Yes the final output of your 'other' amplifier can drive a FET, BUT you must consider the output of the 'other' OPA may swing +/-V, so it will determine how your FET is connected.
Its a STAR ground, ALL the grounds shown are taken to a Common point, which is the phantom ground.
Post a diagram of your planned circuit and we will advise.
Eric
"Good enough is Perfect"
PIC tutorials:
Gramo's: www.digital-diy.net/
ericgibbs is online now
Old 1st June 2007, 08:54 AM   (permalink)
This diagram may help to make it clear.
Eric
PIC tutorials:
Old 1st June 2007, 02:18 PM   (permalink)
That makes tons more sense! thank you so much for your help, Ill see what I can do for a diagram, and hopefully I can create something useful! thanks
H-Bridge DC motor driver MrNobody Electronic Projects Design/Ideas/Reviews 44 6th January 2009 02:55 AM
**need help with AC to DC and DC to DC power supply TT** ahdehling Electronic Projects Design/Ideas/Reviews 5 25th June 2007 09:40 PM
DC power plant design question Dialtone General Electronics Chat 6 1st June 2007 11:06 PM
Basic DC DPauljr Electronic Projects Design/Ideas/Reviews 1 3rd April 2007 03:24 PM
24 to 12 volt Dc to Dc converter windozeuser General Electronics Chat 4 30th January 2007 03:15 AM
