Old 31st May 2007, 12:49 AM   (permalink)
Default power supply question
I am building a +/- 24VDC power supply and have built the 317T/337T voltage regulating portion. Since I would like to regulate the current also my question
stems from the position of the voltage/current regulation stages.
As it stands now I am in a more convient place to have the voltage regulation stage stemming from the Transformer and feeding the current regulating stage.
Does it matter which stage goes first, the voltage or current stage? If so what might be the pros and cons...
Thanks guys... or galls!
iONic is offline
Old 31st May 2007, 02:18 AM   (permalink)
If you use an additional LM317 and LM337 as current regulators then they should be ahead of the voltage regulators because they have a voltage loss across them of up to about 3.25V each. The voltage loss across the current regulators varies with current so if they were after the voltage regulators then the output voltage would have very lousy regulation.
audioguru is offline
Old 31st May 2007, 02:38 AM   (permalink)
What is the purpose of current regulation usually? Is battery charger one of the application? To limit the charging current. Otherwise the battery will be charged by the maximum current produced by the voltage regulator?
Am I right?
Superman returns..
bananasiong is offline
Old 31st May 2007, 03:01 AM   (permalink)
essentially I am building a bench supply to test generally small circuit builds. I want current restriction so I don't blow parts when mis-wireing takes place.
iONic is offline
Old 1st June 2007, 11:11 PM   (permalink)
For a start the LM317/337 are already current limited so it shouldn't be an issue.
You might want to restrict current to below 1A so this is still a perfectly valid question. If look at the datasheets for the regulators you discussed in you post, you'll see that you can also congfigure them as current regulators. The idea is to connect a current regulator in series with you voltage regulator but you need to be aware of the fact that the current regulator requires a minimum extra 3.2V of overhead.
Screen name: Aloone_Jonez
Hero999 is offline
Old 1st June 2007, 11:35 PM   (permalink)
Is that basically the dropout voltage + the 1.25V ref voltage?
speakerguy79 is online now
Old 2nd June 2007, 12:14 AM   (permalink)
Yes.
There's also a circuit on the datasheet which reduces the voltage to 1.25V when excessive current is being drawn. It's probably good enough for most purposes, failing that, I have a circuit which enables you to achieve 0V that can be adapted to have current limiting.
Hero999 is offline
Old 2nd June 2007, 03:45 AM   (permalink)
Take a look at the LM723 - an old but still useful linear regulator. A relatively simple supply can be constructed that offers adjustable current limiting and variable voltage. I use the word "adjustable" in order to call attention to the fact that adjustments are made at higher levels of power that can't be handled with a common potentiometer.
stevez
stevez is offline
Using a LM2679 for a power supply, question about ratings FusionITR General Electronics Chat 8 22nd February 2008 11:03 PM
power supply question raphaelriv General Electronics Chat 3 21st May 2007 09:33 PM
OP2134 Power Supply Question gramo General Electronics Chat 9 14th May 2007 03:36 PM
Using a computer power supply WITHOUT a computer? grrr_arrghh General Electronics Chat 13 4th April 2007 01:15 AM
POwer question. Im using power from micro and seperate one cubdh23 Micro Controllers 3 25th April 2004 01:03 AM
