Old 30th May 2007, 01:30 PM   (permalink)
Default Charging and discharging a battery simultaneouly
I saw a circuit which clams to be an automatic battery charger. I am getting confused, because I thought that charging and discharging a battery at the same time will do more harm than good, or what do you think?
You may have a look at the schematic here: http://www.aaroncake.net/circuits/charger2.asp
ebuka_2 is offline
Old 30th May 2007, 01:36 PM   (permalink)
You don't really charge and discharge at the same time, the PSU will supply power to the load AND the battery when the mains is on, and if the battery isn't fully charged.
Old 30th May 2007, 01:37 PM   (permalink)
Depends on the type of battery. Think of your car battery - it is ALWAYS being powered by the alternator whenever the car is running, and those batteries survive it just fine - and that's the same type of batteries the charger is designed for.
EEgeek.net
evandude is offline
Old 30th May 2007, 01:52 PM   (permalink)
Do you mean it can work with a lead-acid accumulator?
ebuka_2 is offline
Old 30th May 2007, 02:12 PM   (permalink)
Looking thru your link, it dosn't say battery charging and discharging at the same time.
It says, the battery will be charged quickly, when fully charged the charger will go into 'float' charge [low current charge].
If a load is applied to the battery and it starts to become 'discharged' the fast charge part of the charger will be switched on, and so on.................
During the fast charge the charger will supply current into the load and the battery.
Of course the load current must not exceed the maximum output of the charger, else the system will fail.
This is the same as a car alternator/battery system.
Does this help?
Eric
"Good enough is Perfect"
PIC tutorials:
Gramo's: www.digital-diy.net/
ericgibbs is online now
Old 30th July 2007, 02:57 PM   (permalink)
Yes it does, thank you.
ebuka_2 is offline
battery charging. manz Electronic Projects Design/Ideas/Reviews 9 8th July 2006 03:04 PM
Car battery charging system Barwick Electronic Projects Design/Ideas/Reviews 1 17th June 2006 12:49 PM
primitive early design for battery charging faomari General Electronics Chat 3 2nd May 2006 04:22 PM
Discharging Mathematical Function of Rechargable Battery odense Robotics Chat 4 19th April 2006 07:33 PM
Stand by charging method for a Car battery Sarac Electronic Projects Design/Ideas/Reviews 3 8th May 2003 01:43 PM
