Old 29th May 2007, 08:15 PM   (permalink)
Default Child's Mini-Pinball Machine
Hello, mi amigos! Forgive my (temporary) state of newbie-ness, and pleeeeease help me out. I can promise good karma, a heart-felt "thank you!", and maybe a free print if you like surrealist fish art.
What I'm trying to do, in a nutshell, is gut a child's toy pinball machine and place it in a beautiful, hand-crafted wooden cabinet. Most of the internal circuitry will be unchanged; I'm primarily interested in the asthetic values of the project...creating a cool cabinet with terrific graphics and a hand-painted backglass, etc., but I still want it to work.
I can handle all of the woodwork, glass, paint, mechanics and maybe some of the simple wiring (splicing/soldering wire together for length, moving electronic 'triggers' around, etc.), but I'm almost completely out of my element on everything else. I'd like to add some more lights (including flashing ones), maybe graft in a set of computer speakers, maybe graft in a light-and-siren gizmo from another toy and such, but I don't even know if this sort of stuff is possible.
HELP....PLEASE! I'm about to open the toy machine up and start taking pictures of the 'guts', and making some sketches. Any advice you folks could give would be invaluable. Don't hesitate to ask for any reference stuff you need to see or know about.
Jettboy is offline
Old 29th May 2007, 10:43 PM   (permalink)
Well, anything is possible Is it an older pinball machine? Does it use any micro controllers? Gut it out and take some pictures and post them, that would help.
Andy1845c is online now
Old 29th May 2007, 11:24 PM   (permalink)
How about brand name/model number to start out. But yeah adding stuff shouldn't be too complicated. It's a metal ball, so a couple of screws, metal strips, or even bare wire could work as a switch. From there its up to you if you want it to do. Suggest you look into timers, like the 555. It's an 8 pin chip with so many uses related to your project, and there is a lot of information on the web availiable, been around a very long tim.
HarveyH42 is offline
Old 30th May 2007, 12:11 PM   (permalink)
I wanted to make a pin ball machine for my A-level design project but the teacher said it was too ambitious and made me make a desk organiser which totally demotiviated me so I got an E.
Screen name: Aloone_Jonez
Hero999 is offline
Old 31st May 2007, 01:02 AM   (permalink)
Thanks for the offers of assistance. I have started the gutting process, have taken a bunch of photos and am currently mapping the wiring layout as best as I can. I'll post all of this material as soon as I finish compiling it. Many thanks!
Jettboy is offline
Old 31st May 2007, 08:07 PM   (permalink)
OK, here are a few of the photos:
This one is the toy pinball machine AS IS (well, as WAS before I took a screwdriver to it:
This one is a sample of the playing field. Note the circled-in-white metal strip in front of the bumper (a steel spring acts as the bumper). I'm not sure, but does the ball (metal) have to contact both the spring AND the metal strip or...
This one is just a sketch of how the NEW cabinet is going to look. Much like a traditional pinball machine, only a little smaller:
And this one is the backside of the playing field. The cluster of wiring runs down from the top section (the 'brain' as I've been calling it), where the circuit board and scoring display are, into the bumpers and ball return assembly:
And finally, at least for this post, is a diagram I've made of where the wires all attach within the body (backside of the playing field) of the machine:
BUT WAIT! There's more on the way...
Jettboy is offline
Old 31st May 2007, 08:29 PM   (permalink)
And, a few more pics. I should mention that this is where everything starts going dim to my lil' pea brain; the circuit board with all of it's attached 'thingies', the LEDS, the power supply (it runs on an AC apapter and wall current), the...well, hell, ALL of the stuff beyond just simple wire stringing and soldering. Unfortunately, I'm afraid this is where most of the modifications I have in mind will probably have to take place.
This is 'the brain' housed in the upper portion (the orange doohicky is a hinge so you can fold the top down for storage):
And this one is the backside of the circuit board:
Is it possible to attach a plug so this guy can run off of just wall current, without the adapter? Can the LEDs be snipped off, soldered onto much longer wires and placed in the play field (under little plastic domes)? Can I add more lights? How would I go about attaching a better speaker, or maybe a SET of speakers? Can the ON/OFF switches be taken off the circuit board and moved elsewhere? Can the scoring display be removed and relocated?
And the really, really, REALLY complex questions...can the sounds and music activated by the targets be changed? Can I attach a small blacklight assembly?
Jettboy is offline
Old 31st May 2007, 08:38 PM   (permalink)
Doesn't look too bad at this point.
Guess the ball pushes the spring into the metal strip to make the switch. Thinking it has to hit it hard, rather than just brush up against it.
The two springs in the ball return are most likely another switch, ball completes the circuit.
Might help to get some masking tape and label the wires before you remove anything. Put some on the wire, and some near where it connects, mark them the same.
Old 31st May 2007, 09:24 PM   (permalink)
No, the adaptor converts the 120v AC from the wall to DC and steps it down to a safe voltage. You'll need to keep the adaptor, or atleast an adaptor of some kind.
I don't see why not. As long as you can manage the soldering. Might be kinda tedious, but it should work just fine.
I don't see why not, as long as you have a way to trigger them, and to power them. What kind of lights did you have in mind? LEDs?
I'm not sure in this area. Hopfully one of the more audio minded members can advise here. I doubt the board has the brawn to drive more then that little speaker.
Don't see why not, as long as you can get extensions soldered onto the board.
This is also past my scope of knowledge. I know it could be done, but i'm not sure how hard it would be. I know some surplus electronic sites sell record/playback modules, mabey you cold use somthing like that for each sound/target. Not the best way to do it i'm sure, but it might be the simplist.
i want mini projects on basic electronics vinay2006 General Electronics Chat 2 7th December 2008 12:32 PM
Washing machine motor... brentonw2004 General Electronics Chat 4 17th May 2006 12:33 AM
mini wheelchair controlled by PIC18F452 kupikupi Electronic Projects Design/Ideas/Reviews 19 30th August 2005 02:32 PM
question about Q-basic controlled machine Dan Rodgers General Electronics Chat 2 11th February 2005 11:40 AM
What is the best idea for a broken Karaoke Machine? reverend Boltron Electronic Projects Design/Ideas/Reviews 3 19th September 2004 10:09 AM
