Old 27th May 2007, 01:00 AM   (permalink)
Default 555 timer countdown
Is there anyways I can make a 555 timer countdown from a number that I choose than fire a switch after so long. Or is better just to use a pic?
Thank you,
Adam
admeech29 is offline
Old 27th May 2007, 01:43 AM   (permalink)
A microcontroller would be a much simpler/cheaper solution if you have the programmer and can write the program. With the 555, you'll need a presetable up/down counter, another chip to convert the count to your display, and something to drive the display. You would also need to decide how you want to set the inital count. There are likely several of these count down timers on the web, cheap ones at Walmart .
HarveyH42 is offline
Old 27th May 2007, 02:17 AM   (permalink)
to calm our nerves, please disclaim that you aren't building an IED
If you don't have a planet, what good are gold bars?
want to contact me directly? gmail gordonthree
check out my project website: http://projects.dimension-x.net
Favorite numbers:
09 F9 11 02 9D 74 E3 5B D8 41 56 C5 63 56 88 C0
justDIY is offline
Old 27th May 2007, 02:24 AM   (permalink)
I am not building and IED. I don't want to just buy a countdown. I can use PIC but I don't know how. Also I wouldn't mind using a 7 segment display. But where do I buy pic's. I want to also be able to program the time into whenever I want to.
Thank you,
Adam
Old 27th May 2007, 02:38 AM   (permalink)
Yeah, I don't know how to use a PIC either... I use AVR microcontrollers. If you already know how to use a PIC, you must know how to program, so the only problem would be the display. Past couple of weeks we had a PIC clock thread going that dealt with multiplexing 7 segment displays. Should be just what you need. Believe they had the code and hardware, but don't remember which PIC or what language, as I don't use PIC, and only done assembly so far, but looking into BASIC.
555 timer output help for a newbee... WIZARDSV650S Electronic Projects Design/Ideas/Reviews 6 6th April 2007 05:04 AM
Countdown Timer buzzer Stevie_j_b Electronic Projects Design/Ideas/Reviews 8 9th March 2007 03:12 PM
Countdown timer clifweb Electronic Projects Design/Ideas/Reviews 3 29th August 2006 06:30 AM
Countdown Timer ctduong1 Electronic Projects Design/Ideas/Reviews 6 2nd November 2004 05:50 AM
countdown timer code ah_Hui Micro Controllers 0 26th April 2004 06:31 PM
