| I'm using a HD44780 controlled LCD, but the display is almost invisible. I'm using a 10k pot from +5 to ground with the wiper to VL to control contrast as the data sheet suggested. If I go from +5 to -5 the contrast is great. Has anyone had similar problems or any suggestions to avoid the dual supply? | |
| Wierd, What is VL? I'm not familiar with it from my LCD's... What Pin# is it? The first three Pins are usually Vss, Vdd, Vee, and I wire it up like this;
__________________ Spency. PIC Micro's - Your mind is the limit PIC's and interfacing with other devices - a PIC Basic Guide @ digital-diy.net | |
Is the Common 0V line connected from the LCD controller pcb to the PIC 0V line?. If you must use a -Vo, do you have a MAX232 RS232 ic on the PIC pcb?, if so, you can tap into the -9V on the MAX.
__________________ Eric "Good enough is Perfect" PIC tutorials: Gramo's: www.digital-diy.net/ Bill's: www.blueroomelectronics.com/ Last edited by ericgibbs; 26th May 2007 at 08:01 AM. | ||
| G'd Day Gramo, Please check the naming of the LCD power connections in your pix, above. The Hitachi manual for the HD44780 says: pin#1 Vss, signal ground.[0V] pin#2 Vdd, power supply for logic.[+5v] pin#3 Vo, power supply for LCD driving voltage.[Vo=> +1.5V] The recommended variable resistor is 10K0 thru 20K0 Regards
__________________ Eric "Good enough is Perfect" PIC tutorials: Gramo's: www.digital-diy.net/ Bill's: www.blueroomelectronics.com/ | |
| I'm using another type of LCD panels.For the contrast I'm using 5K V/R and sometimes in ohms scale fixed resistor value. My LCD manufacture recomends that you must connect the V/R in between the V0 - contrast reference supply & Vss - Ground. If the back light is too bright also its hard to adjust the contrast well.also some back lights like blue colour draws much more current than others. | |
My little datasheets said 4.7K to 10K I'll look around and confirm it
__________________ Spency. PIC Micro's - Your mind is the limit PIC's and interfacing with other devices - a PIC Basic Guide @ digital-diy.net | ||
| you must have an 'extended temperature' lcd, which requires negative voltage for contrast. stealing a little -V from a max232 is an awesome and easy idea, you can also generate some using a charge-pump consisting of two capacitors and two diodes driven by a sq. wave from your microcontroller. another option is a dedicated charge pump controller - Microchip has an easy to use SO8 verison that works with inexpensive ceramic caps.
__________________ If you don't have a planet, what good are gold bars? want to contact me directly? gmail gordonthree check out my project website: http://projects.dimension-x.net Favorite numbers: 09 F9 11 02 9D 74 E3 5B D8 41 56 C5 63 56 88 C0 | |
I use the -V from the max for graphic displays. You can steal upto 10mA from the +/- lines of the MAX232, I usually make the MAX caps 4.7uF or 10uF, when I do that. Use the +/- 9v thru 78/79L05 for opa supplies.
| PIC16+Parallel lcd - by twitchy | Nigel Goodwin | Micro Controllers | 16 | 18th May 2007 11:44 AM |
| 8 bits LCD Problem | joe_1 | Micro Controllers | 3 | 27th April 2007 02:38 AM |
| 89c4051 4-bit controlled LCD sporadic screwup | Pax Writer | Micro Controllers | 7 | 26th April 2007 06:58 AM |
| LCD Template Code For PIC16F84A (Help) | Peter_wadley | Micro Controllers | 23 | 4th April 2007 04:47 AM |
| Contrast problem Optrec 20171 LCD Unit | Dialtone | General Electronics Chat | 3 | 18th April 2004 11:48 PM |
