Old 25th May 2007, 09:14 PM   #1
Default Air Temp Sensor Conversion???
I would like to create a circuit (assuming needing a micro) to convert the sensor output of one NTC air temperature sensor to another. The two sensors have completely different voltage/temperature cures and are not linear. What would be the best way to go about taking one voltage input and converting it to another? Both sensors are run from 0-5 volts.
fritts is offline
Old 25th May 2007, 09:28 PM   #2
get another sensor...
it's quite hard to produce analog signal with a micro.
Need Help?
Press F1
If that doesn\'t help you, ask me... I might know better.
bloody-orc is offline
Old 25th May 2007, 09:39 PM   #3
The issue is that the stock sensor is a closed element and does not react very quickly. I am trying to use a standard GM air intake temperature sensor with an open element to supply air temps to the ecu.
fritts is offline
Old 26th May 2007, 01:36 AM   #4
Prob is that a sensor has a variable resistance. There are ways to do this with a PIC's pwm output but it varies depending on the circuit reading it. A resistance output is not so straightforward as a voltage output.
I'm in the "get another sensor" camp. Maybe you could cut up the GM sensor housing and insert the thermistor you took out of the stock sensor.
Oznog is offline
air, conversion, sensor, temp
ds1307 with 89c51 baftab Micro Controllers 20 28th May 2007 10:27 AM
LED Temp Guage using a LM3914 IC?? MINI-IZED Electronic Projects Design/Ideas/Reviews 2 10th May 2007 04:05 PM
problem in getting temp from ds1621 esconele Micro Controllers 3 31st May 2006 01:12 AM
voltage regulation by temp theboss Electronic Projects Design/Ideas/Reviews 2 30th May 2004 08:30 PM
converting binary number to ASCII code david_mora Micro Controllers 7 24th May 2004 10:08 PM
