Hi there,
I'm building a timer for stairs. You can see the attached schematic.
The circuit is working well.But I'm meaning to make some changes in it for some reasons:
You know, the circuit is drawing current all the time even when nobody is using the light. I have seen the timers that one head of the switch in them is connected to the mains so whenever the switch is hitted the timer starts to work. But I can't figure out the trick for this circuit. Do you know the trick?
The other benefit of this circuit is that the number of the outputs reduce to 4 and so it's more commercial in wiring.
Appreciated for your assit.
