Old 21st May 2007, 04:06 AM   (permalink)
Terry335 is on a distinguished road
Default Help with basic voltage reducing circuit for auto
*** Protected Info ***
Terry335 is offline   Reply With Quote
Old 21st May 2007, 01:13 PM   (permalink)
Experienced Member
Norlin is just really niceNorlin is just really niceNorlin is just really nice
Send a message via ICQ to Norlin Send a message via AIM to Norlin Send a message via MSN to Norlin Send a message via Yahoo to Norlin Send a message via Skype™ to Norlin
am no expert here, but I'm guessing you could use an undervoltage sensing IC such as the MC34164P-3 http://pdf1.alldatasheet.com/datashe...C34164P-3.html
Have the normal power go through a transistor, when the voltage hits 3V, have current flow through the MC34164P-3 to the circuit as well as the base of the transistor to turn it off (perhaps a PNP with an inverter between it and the MC34164P). Between the MC34164P-3 and the circuit, have something that will make the voltage climb slower. Just my probably not so great idea, hope it helps stir up some better ideas.
Norlin is offline   Reply With Quote
Old 21st May 2007, 02:24 PM   (permalink)
3v0
Moderator
3v0 is a splendid one to behold3v0 is a splendid one to behold3v0 is a splendid one to behold3v0 is a splendid one to behold3v0 is a splendid one to behold3v0 is a splendid one to behold3v0 is a splendid one to behold
Do you need to consider throttle position, rpm, and maybe time ?
I do not know, if you do not you need to find out.
3v0 is online now   Reply With Quote
Old 21st May 2007, 03:01 PM   (permalink)
Experienced Member
It could be done using a couple of op-amps and a voltage reference IC but it's a bit long-winded.
Use a subtractor to get 0-1.3V divide it by 1.083 using a potential divider, then add 1.9 using an adder.
Old 21st May 2007, 08:55 PM   (permalink)
Experienced Member
in this circuit, even though you're diverting away some of the current you're not changing the voltage at the point where the circuit splits.
suggestion for circuit to limit o/p voltage Flying General Electronics Chat 1 5th October 2006 10:44 AM
Resistors Marks256 General Electronics Chat 52 3rd August 2006 01:00 AM
I am not getting ripple voltage at the output dar2525 General Electronics Chat 3 14th July 2005 02:20 PM
Basic Subject About Integrated Circuit Enable Pin :o) senem Electronic Projects Design/Ideas/Reviews 2 11th June 2005 12:11 AM
Voltage Comparsion Circuit needed waqar Electronic Projects Design/Ideas/Reviews 1 16th May 2003 12:09 PM
