Old 30th August 2003, 08:37 PM   (permalink)
Default convert a manual switch to an electronic switch
Application:
I have a RF receiver attached on a pole that is connected to a computer inside a trailer. The RF rec has a 4 position switch (manual) that I want to convert to an electronic switch that will be activated inside the computer so that the the computer can rotate (electronicly) thru the 4 posotions on the switch in the RF receiver.
I'm going to run a wire (from an existing cable) from each position on the the switch in the RF amp down to the computer and I need to attach the electronic switch to these four wires to rotate the switching.
So basicly I need the circuit to provide the electronic switching from the computer.
Any help in this regard would be greatly appreciated.
Dolphin
dolphin is offline
Old 1st September 2003, 06:04 AM   (permalink)
What you need is an analog switch.
I used them with Linx chips on the address pins to replace dip switches.
There are four switches per IC.
My Circuit Setup:
I believe i used dg211 which are normally closed switches
Hooked the IN1, IN2, IN3, IN4 to parallel port pins
Hooked D1, D2, D3, D4 to GND
Hooked the S1, S2, S3, S4 to the address pins on the linx modules.
Parallel Port Pin Logic | Address Pin's Logic Input
0V | GND
5V | High Impedence state
ordered them from digikey but you can also get samples on their website
http://www.maxim-ic.com/quick_view2.cfm/qv_pk/1315
Hope this works for you.
DaKandEKid is offline
