Old 20th May 2007, 04:01 PM   (permalink)
Default Notch filter w/schmitt trigger
Hi. I'm currently in the process of designing a tunable notch filter for frequencies between around 2kHz to 15Khz. The notch filter is tuned by adjusting resistors R2 and R3. The device will need to 'switch on' an LED when the notch frequency is being presented at the input. I chose to implement the LED activation mechanism by using a schmitt trigger that would 'compare' the output voltage of the filter to the output voltage of the input signal, upon passing them both through a basic rectifier/smoothing section.
I'm using an Op-Amp for the schmitt trigger. What i'm having trouble with is configuring the schmitt trigger's ON and OFF hysteresis limits. Essentially, when the voltage difference at the inputs equals roughly 2.6V, i want the schmitt trigger to go 'negative rail'. When the difference at the inputs equals 3.8V i want it to go 'positive rail'. How can i go about doing that? Please take a look at the circuit diagram for opinions.
Thanks alot.
whirlwindz is offline
Old 20th May 2007, 08:24 PM   (permalink)
Please do not make duplicate posts or threads, they do not increase your chance of a helpful response but only reduce it, as people get confused and can't always see what others have suggested in the other thread(s).
If you have made this post or thread in error then please do not be offended. We get lots of people making duplicate threads under the misapprehension that it will increase their chance of a helpful response when in practice the reverse is true.
Have a look at the tutorial; it will help you to calculate the hysteresis values.
http://home.cogeco.ca/~rpaisley4/Comparators.html
Screen name: Aloone_Jonez
Hero999 is offline
Old 21st May 2007, 03:23 AM   (permalink)
The LM348 has four very old 741 opamps in it. They have poor response above 9khz and lots of phase shift.
I recommend that you use a TL074 quad opamp that works well up to 100kHz.
audioguru is online now
Need help with Schmitt trigger application! whirlwindz General Electronics Chat 8 23rd May 2007 01:06 PM
Notch Filter. lord loh. General Electronics Chat 4 18th July 2006 06:52 PM
Filter problem... Very urgent pls.. kingkong83 Electronic Projects Design/Ideas/Reviews 23 19th October 2004 02:40 AM
Notch Filter Woes... nfway General Electronics Chat 15 1st December 2003 03:41 AM
Audio Notch Filter ElectroMaster Electronic Projects 0 25th July 2002 02:11 AM
