| Hello Everyone! I am trying to design a 14.5V Battery Charger with 200mA current limit. I have no need for Variable Voltage or Current adjustments (just simple design for 1 type of battery I have). I already designed this circuit using LM317. Some one please tell me if this circuit will work for this use... Circuit Notes: The first LM317 with R1 is there to limit the current to 200mA (1.25V/6=200mA). The second LM317 is for voltage regulation [1.25x(1+10.6k\1k)=14.5V]. Question #1: Is 20VAC input enough? Should I use 24VAC instead (more HEAT) ? Question #2: When choosing CAP 1 Voltage, should my orientation be based on Vp or RMS? Thanks ! Last edited by Frosty_47; 20th May 2007 at 04:04 PM. | |
| hi frosty, Looked thru your circuit, its over elaborate for a charger/current limited.
__________________ Eric "Good enough is Perfect" PIC tutorials: Gramo's: www.digital-diy.net/ Bill's: www.blueroomelectronics.com/ Last edited by ericgibbs; 7th July 2008 at 12:20 PM. | |
| Hi frosty, You should reduce R2 and R3 at least by a factor four. A good value for R2 is 220 There shouldn't be any problem if the battery ( or a load ) is permanently connected, but when no load is present the output voltage will rise well above the calculated value because you forgot that the LM317 also needs current to function and there isn't a direct path to ground. They usually solve this problem by taking lower resistance values for the voltage divider. You can also solve this problem by connecting a small permanent load like a led and it's series resistor. 5 mA through the led is enough to solve this problem. You also forgot that each battery charger needs to have a reverse blocking diode in case the mains runs out of power when you're charging a battery. The 2200 µF capacitor will charge up to the peak value. on1aag. Last edited by on1aag; 20th May 2007 at 09:15 PM. | |
| I would even consider setting R2 to <120
| The LM317 needs 0.1uF at the input for stability but you don't need any other capacitors for battery charging. The battery itself is like a large capacitor.
| Most power supply circuits, including chargers, I have come across have the voltage regulator first then followed by the current limiter. Don't know if that is a technical requirement but I would research that a little if you can. Others comments on that? Lefty | |
| Ayt, I updated the design. I still plan to use a 2200 uF Cap because I have it laying around Changes to previous circuit: Put in D5-D6 to protect the charger from reverse current when it is off and still connected to battery. Replaced R2 with 240 Ohm because thats what the datasheet for LM317 recommends. R3 was also reduced to 2.8k [1.25x(1+R3/R2)-(1.4V drop due to D5&D6) =14.5V]. Increased the Input Voltage to 24Vac due to transformer availability. Added RL for LED to eliminate no current operation. One thing still not clear to me... Should my CAP voltage be based on Vp or RMS when dealing with AC ? Thanks a lot for all your HELP!!! | |
| Hi Frosty, When you changed the values of the resistor divider network of the LM317, the extra load with the led was no longer necessary. These resistors load the regulator as well, that's the reason why they select those low resistance values for it. But you should keep the led in the circuit, it's always handy when you can see wether it's working or not. You should remove D6, one diode is enough. Keep us informed of your progress. on1aag. | |
| Ayt thanks a lot for your help on1aag ! I will still keep RL because I need it for the LED. Removing D6 will make very little difference because the diodes come in packages of six at the place where I buy em, so might as well keep D6 for that extra protection I had one question rise up before me during all this, how do I hook up an LED that will be on during Load/charging operation ? Thanks again ! BY THE WAY, BLIZZARD HAS ANOUNCED STARCRAFT 2 IN DEVELOPMENT !!! Last edited by Frosty_47; 21st May 2007 at 01:49 AM. | |
| Hi Frosty, Maybe there is a way to put D6 to good use. The voltage drop accross R1 is 1,25 volts when charging. That is a little too low to light a led, but if you put the useless D6 in series with this resistor the total voltage drop will be close to 2 volts and that is enough to light a led. The 22 through the led, but this might vary slightly because the voltage drop accross a red led varies from 1,6 to 1,8 volts. So check it out and adapt the value of the 22 to let the led light as bright as the other one. on1aag. | |
| The capacitor charges to the peak of the AC and you should allow for some safety margin. The peak of 24VAC is 34 V so use a 50 volt capacitor at least.
| I updated the circuit. Thank you very much for all your assistance in this design. I will go ahead and start building this circuit on Tuesday. I still have to design the PCB layout for this circuit using Eagle (that might take a while), so hopefully I will have it working by Wednesday. Anyhow, I will post the results as soon as I can... Thank you every one for your time, interest and suggestions !!!-!!! | |
| Isn't it 120
__________________ Superman returns.. | |
The datasheet shows a more expensive LM117 using a 240 ohm resistor because its max operating current is lower, it is only 5mA. But in this circuit, the LED adds enough load so that a 240 ohm resistor is fine. I calculate an output voltage of 15.1V which is too high for a lead-acid battery. If the 2800 ohm (odd value) resistor is changed to a 2700 ohm standard value then the voltage will be 14.6v.
| constant voltage, constant current Lead Acid Battery Charger | Erwin_Macaraig | Micro Controllers | 1 | 4th October 2008 01:26 AM |
| Lead Acid battery charger | manojp01 | Electronic Projects Design/Ideas/Reviews | 5 | 29th January 2008 06:17 PM |
| Battery charger help... | dieselmo34 | Electronic Projects Design/Ideas/Reviews | 14 | 18th December 2006 06:30 PM |
| Battery charger for mobile phone Motorola | 2PAC Mafia | General Electronics Chat | 0 | 4th October 2005 04:20 PM |
| To design and build a 6V NiMH 9000mAh battery charger | kiwibikey | Electronic Projects Design/Ideas/Reviews | 1 | 28th March 2004 06:58 PM |
