Old 19th May 2007, 09:22 PM   (permalink)
Default LM317T Voltage regulator hookup question
http://ourworld.compuserve.com/homep...den/page12.htm
here is the information I am looking at, in his diagram, I understand what is going on, except for the part near the right side labeled "(-) return" .
Does this negative go to ground? it doesnt really say... and as for adding a capacitor, what IS transient response?
thanks in advance for adding your .02
evotec1 is offline
Old 19th May 2007, 10:12 PM   (permalink)
Correct.
The output voltage of the LM317 is supposed to be constant and indipendent of the load current. However, if the current changes suddenly, the output voltage shows over(under)-shoots.
The datasheet shows that their amplitude is reduced by adding the output capacitor.
eng1 is offline
Old 19th May 2007, 10:33 PM   (permalink)
[quote=evotec1]http://ourworld.compuserve.com/homep...den/page12.htm
I you follow that (-) return line all the way to the left in your posted drawing you will see the 'ground' symbol, looks kind of like a upside down tree.
Now this 'ground' may not mean that it actual goes to earth ground somehow, but it could. What it really means is that the (-) side is hooked to the 'circuit common' and all other voltages are referenced to this common. When a voltage lead is labled say +12 in means a positive 12 volts referenced to circuit common. Again that common may or may not be to 'earth ground' potential, but that is another topic in it's self.
Clear?
Lefty
Leftyretro is offline
Old 20th May 2007, 12:43 AM   (permalink)
i'll draw some pictures of how i have it hooked up, i have a few of em if i mess something up
evotec1 is offline
Voltage ElectroMaster Electronic Theory 44 8th August 2007 06:35 PM
voltage modification... newbie question, please help!... catboy Electronic Projects Design/Ideas/Reviews 9 19th September 2005 03:41 PM
Voltage reg or voltage reference. Screech General Electronics Chat 4 13th May 2005 07:57 AM
Low Battery Voltage Alarm elfvenlord Electronic Projects Design/Ideas/Reviews 18 29th July 2004 05:31 PM
LM 311N Voltage Comparator Question elfvenlord General Electronics Chat 7 16th July 2004 07:22 PM
