Hey Everyone,
I am building a PCB for flashing headlights on my freinds vehicle (he is a volunteer fireman) I am using a basic 555 timer with a 1Kuf capacitor and a 300 Ohm resistor for the flash timing. I utilize the high and low states of the 555 and thats o.k when using LED's because the polarity can be reversed. Now I want to use (2) 555's and switch the headlight lamps (wig-wag) ... I don't think a PCB miniature relay could switch that fast, and even if it could it would'nt last very long. Now I am hoping someone can help me find an IC or other component that is capable of switching heavy lamp loads very fast and can do it by the 555 pulse I send to it. All suggestions appreciated very much. Jim P.S I pondered the idea of having enough 555's in paralell to handle the load but that would be a heck of a lot of timers because I think they are maxed at 200ma.....
"Yesterday is History, Tomorrow's a Mystery" |
555s in parallel would fight each other then blow up.
A 555 can drive a Mosfet that can switch very a high current light. Then an inverting transistor and another Mosfet can drive the other light as a wig-wag.
Uncle $crooge |
Would'nt want a meltdown ! I'll look into MOSFET's , do you suggest any certain type ? Or should I just go by the load it's serving ?
Over-rate the current for the Mosfet because an incandescent light bulb draws up to 10 times its rated current when it is cold. Its filament gets pretty cold between flashes.
Uncle $crooge |
60-100V 5A ( IRF510 ), That should do it, ya think ? and one more thing scrooge, should I put capacitors across the lamps ? Or dont I need em... and if I do what size ?Thanks again
I just checked the data sheet, I don't think the 510 will work because I am only looking at 12V switching voltage and mv gate voltage ? Goin to bed I'll check more in morning, any suggestions ? Thanks
see my website: www.geocities.com/russlk |
A car's headlight is 60W isn't it? Then its current at 13.8V is 4.3A when it is hot, and maybe 43A when it is cold.
An IRF510 Mosfet is very old and cannot switch such a high current. An IRF540 Mosfet is also pretty old and fairly cheap and conducts 11 times better. There are hundreds of newer and better Mosfets. The IRFZ44 has a max current rating of 200A for pulses and a max on-resistance of only 28 milli-ohms. If it has the proper driver circuit then it would do a good job to flash headlights.
Uncle $crooge |
Will the MOSFET's you all mentioned switch the low 12V ? Thats where I am confused , the datasheet states 60-100V does that mean max value ? Because I saw (on the spec sheet ) minimum V as 60..... So I just need to know if the one you said was better to use will switch 12V Thanks, Jim
The max voltage rating of a Mosfet is the max voltage allowed. A higher voltage will break it. It will switch a voltage as low as 1V.
Uncle $crooge |
Considering this is a fairly 'important' function, and the OP doesn't seem exceptionally electronics minded, I would suggest the easiest (and most relaible) way would be a 555 timer feeding a transistor and car type relays - minature relays are probably too small. Flashing speed isn't a problem, it has to be fairly slow due to the thermal inertia of the bulbs - car relays will be more than fast enough.
JB,
this thread I wrote a while back may be of interest to you. the circuit was originally designed to flash led tail-lights, but choose the right mosfets and it should be able to switch headlights just fine. http://forums.linear1.org/index.php/...9.html#msg5129 ![]()
If you don't have a planet, what good are gold bars? want to contact me directly? gmail gordonthree check out my project website: http://projects.dimension-x.net Favorite numbers: 09 F9 11 02 9D 74 E3 5B D8 41 56 C5 63 56 88 C0 |
Thanks for all your help..... much appreciated..
| Current Source and current mirrror | lord loh. | General Electronics Chat | 12 | 25th April 2006 08:51 AM |
| Having problems with pic16f872 | cjgalway1000 | Micro Controllers | 0 | 7th April 2004 02:39 PM |
| high power switching for 12hours | Asjad | General Electronics Chat | 4 | 7th April 2004 11:45 AM |
| High Speed Internet Splitting? | LiquidOrb24 | Electronic Projects Design/Ideas/Reviews | 7 | 5th February 2004 11:15 PM |
| i need an advice on lamps for high speed switching | _4nickando | Electronic Projects Design/Ideas/Reviews | 1 | 12th December 2002 03:50 PM |
