| Hi, I develop for one my project board with Attiny2313. This board have one relay and two inputs. I use for control some sewing-machines. When develop I add some connectors what I don't use in this project. Board have connector for RS232 (VCC, GND, TX and RX) and connector with all pin’s PORTB. Because now I have some free boards I want to make using this board some other projects. I know enough C++ programming for firmware Attiny2313, but newer write PC software. All my other projects require PC software to communicate with board or for adjustment parameters using RS232 instructions. For this I will use RS232 module with MAX232 and USB to TTL module with FTDI chip. Some exemplary projects I like to make: 1. Connect one Digital thermometer DS1820 firm DALLAS and read in PC actual temperature. 2. Connect one DS1820 and make thermostat where min i max temperature adjust through PC. 3. Make universal timer with one relay where time adjust through PC. 4. Using board connected to PC to log (watch) 8 inputs. 5. Using board connected to PC to control 8 outputs (for this I will use one board with 8 relays). I have hardware and will write firmware for board. Maybe someone will need similar device and help with PC software? I add scheme and photo this board. Best regards and thanks for all replies. | |
| Best battery for the micro projects. | mramos1 | General Electronics Chat | 30 | 27th May 2006 01:10 PM |
| Transmitting small voltages | aibelectronics | Electronic Projects Design/Ideas/Reviews | 8 | 24th May 2006 06:11 PM |
| IMPORTANT!!!! PLEASE READ BEFORE POSTING!!!! | ElectroMaster | Electronic Projects | 0 | 8th June 2005 12:34 AM |
| max232 projects | reverendm | Micro Controllers | 5 | 5th March 2005 09:22 AM |
