| Ok, maybe the words are misleading. I have ONE microphone, which is powered. It comes with battery inside a small box. SO I think it is powered. In this case I don't nedd R1, do I? Becasue, R1 serves to power the mic. The OPAMP should separate the two input of the preamps. In this way their reciprocal input impedence should not be affected. Suppose now that the mic is not powered: I have to power it, haven'I? In this case, I use R1, and again the OPAMP separate the two preamps. Don't you agree? | |
| The purpose of R1 is to power the mic. So if your mic has a battery then tou don't use R1. The mic preanp I showed has an input impedance of 50k ohms. You could connect up to 10 of them to your mic and they won't affect it. So the extra opamp is not needed.
| OK , but I don't know which is the input impedance of the other preamp(remember that it is a closed box to me) G | |
| I implemented the audioguru's preamp, and an amp with tda052 from philips. The mic is an electrect, I think. It is 2 terminal mic which need a power source. Now the problem is that the system is to powerful! I can hear sounds very far from the mic...and also I can easily pick up the sound emitted inside the earphone capsules, located more far than 50cm, generating a larsen effect. Actually, I did not inserted the potentiometer inside the preamp, so the gain is fixed. I just used a signal reduction at the ingress of the tda. Any suggestion? G | |
The preamp gain is set by the value of its pot like this:
| Than kou for your time, audioguru. I will insert the pot. However, there is a way to know which the peak-to-peak output of a typical electret mic? More, may I ask you which eda do you use to draw schematic and to do simulations? Regards | |
| The output of a mic depends on how far away from your mouth it is and how loud you speak or sing. A low load impedance reduces its level. It is typically about 14mV p-p. I use Microsoft Paint program to make schematics. Straight lines are made with the Shift key down and most things are copied and pasted from other schematics or datasheets. I use SwCAD III from Analog Devices simulation program that is excellent and is free.
| I'm a throwback, I use DPaint IV on an Amiga 1200. Schematic symbols are copied as "brushes" and stamped onto the pic, then connected with straight lines. I have text on some of the more common values already. | |
I loved DPaint!. | ||
| I have Dpaint V on a 800mhz Amithlon box, but for some reason I find IV much more useful. | |
| Is that the DOS version or are you using an emulator?
| Amithlon is an emulator/licensed OS & ROM package for 68K based Amiga OS's. It includes Workbench 4.0, but you can run newer or older versions on it as well. It supports Cybergraphix, but not AGA, so 1200/4000 specific apps won't work in AGA modes. That is why I'm using DPaint IV on the 1200 and Dpaint V on the Amithlon box. | |
| Electronic system to stop sleeping problems - help with design of system | ZackSmith | Electronic Projects Design/Ideas/Reviews | 1 | 29th October 2006 10:43 AM |
| Electric firing system - Fireworks (again) | iamcat | Electronic Projects Design/Ideas/Reviews | 3 | 17th June 2006 03:27 PM |
| Car battery charging system | Barwick | Electronic Projects Design/Ideas/Reviews | 1 | 17th June 2006 12:49 PM |
| Consulting on Switch system. | GOMBO | General Electronics Chat | 1 | 26th September 2004 10:28 AM |
| i need a circuit diagram of pic based alarm system.. | BurhanUnalmis | Micro Controllers | 0 | 26th April 2003 03:44 PM |
