May you suggest to me a simple power amplifier?
I have been using one based on TDA052 which is difficult to find here... Regards |
Your mic preamp with two inputs won't work. You cannot feed a signal into the extremely low output impedance of an opamp.
You need to have separate preamps for each mic then an inverting opamp as a mixer. Use an LM386 small power amplifier to feed the headphones. Its output power is less than the TDA7052. Its voltage gain is preset to 20.
Uncle $crooge |
Two questions:
1) I wanna use one input at time 2) May I put a condenser between the output of the voltage follower and input 1 or 3) may I put a switch on the supply line of the opamp, in such a way that when the input 1 is inserted, the opamp will not affect Regards |
The voltage follower doesn't do anything except short the second input. A capacitor in series with its output would allow some low frequencies in but still short high frequencies.
You need a separate preamp for each mic then an inverting opamp as a mixer.
Uncle $crooge |
Isn't there a way to override the preset gain of the LM386 using a couple of capacitors?
But if I don't put anything on the Pin Number 1 (my mic), the ooutput of the opamp will feed my preamp, dont'it? If I do not put anything on the second input, and instead I use my mic and also turn off the OPAMP, why the mic would be shortned? |
If the gain of 20 is too high then simply use an attenuator made with two resistors to reduce the input level.
Uncle $crooge |
(permalink) | ||
Uncle $crooge |
The output impedance (resistance to AC) of the opamp is so low that the signal coming from your mic is going to be shorted out to almost nothing by the very low resistance. Remember that electric current always takes the path of least resistance in proportion to all the resistances at that point in the circuit.
So, I thought to put a double switch in order to completely disconnect the OPAMP. It is not a professional solution but I think it does work. G |
Your two preamps and a mixer can be part of the same IC package, so you really wouldn't be looking at that much of a time/cost increase.
Yes ,right, but I have not tool to make the pcb layout, I have only general purpose pcb boards. By the way, have you some mixer to suggest?
Regards G |
So, sorry of boring everyone, I thought to do this solution, instead of using a mixer.
If I use a pre-powered mic, I will switch-off the R1 resistor. In this way, the OPAMP should separate the two preamp. If I use a non-powered mic, I will switch on the S2 switch, and in this way the R1 will power it. Don't you agree? G |
I have no idea what you are doing with the opamp as a follower and switching R1.
Where is the second microphone going to connect to?
Uncle $crooge |
| Electronic system to stop sleeping problems - help with design of system | ZackSmith | Electronic Projects Design/Ideas/Reviews | 1 | 29th October 2006 09:42 AM |
| Electric firing system - Fireworks (again) | iamcat | Electronic Projects Design/Ideas/Reviews | 3 | 17th June 2006 02:26 PM |
| Car battery charging system | Barwick | Electronic Projects Design/Ideas/Reviews | 1 | 17th June 2006 11:48 AM |
| Consulting on Switch system. | GOMBO | General Electronics Chat | 1 | 26th September 2004 09:27 AM |
| i need a circuit diagram of pic based alarm system.. | BurhanUnalmis | Micro Controllers | 0 | 26th April 2003 02:44 PM |
