| I made a mistake on my drill hole sizing on a board, and the through plated holes for my header pins were only drilled to .028", instead of .040". Do any of you know of a header pin with round tails that will fit in a .028" hole? | |
| Just mount the header pins in a Dremel tool or power drill/drill press and use a grinding stone on the spinning half to hand mill it to the required size. As long as it's only one board and not a huge number of pins it shouldn't be too difficult. The header pins can be marked with a permanent marker and removed with a pair of pliers easily. Depends on exactly how many header pins you're talking about.
| I could do that, but it is more like 50 boards. I found two companies that may make pins that will solve my problem, Mill-Max and Commcon. | |
What kind of header do you need? i.e. What is the spacing and number of rows? And do you need male or female? - Tom Gootee http://www.fullnet.com/~tomg/index.html - | ||
| I want .100" spacing, 1 x 10. I want .025" square pins on one side, and round pins that will fit into a .028 hole on the other. | |
| Major Help Needed Please: Peltier and 2 channel fan controller needed :S | MR Spade | General Electronics Chat | 16 | 23rd November 2007 04:10 PM |
| naming a pin or bit question | hotrodhed120 | Micro Controllers | 7 | 8th May 2007 05:50 PM |
| Header pin jumper wires. | Sceadwian | General Electronics Chat | 23 | 21st February 2007 10:58 PM |
| PIC USART: Help Please | mortuzahasan | Micro Controllers | 2 | 11th February 2007 07:28 PM |
| Newcomers, please read! (PIC regarded) Upd. 0xD | Jay.slovak | Micro Controllers | 0 | 17th April 2005 02:05 PM |
