| Hi i was wondering if someone can help me with a project i'm working on I need to step up my inverter from 240vac to about 2500vdc I'm using the old cap/diode method however i am unsure of the ratings needed I read somewhere of using photo caps with twice the rating for voltage/ampage, so i thought i'd ask to be on the safe side. Any help would be appreciated. | |
| What current do you require? If you want lots of power then a cheap way would be to use a microwave transformer and voltage doubler circuit from an old microwave oven. Don't listen to anyone who tells you, you can charge photo capacitors to double their rated voltage without them exploding. Also capacitors don't have a current rating unless you're talking about the ripple current which is only valid at AC.
| cheers bud The ampage isnt much of an issue just high voltage thanks for the info | |
| A MOT would probably work pretty good if current isnt an issue. I think t he caps for the voltage multiplier circuit need to be rated at 2X the peak input voltage, so 240 AC would be around 700V.
__________________ Jeff To the optimist, the glass is half full. To the pessimist, the glass is half empty. To the engineer, the glass is twice as big as it needs to be. | |
| a safer way would probably be a neon sign transformer, although they put out a voltage a bit higher that you want. If your lucky you might find one to suit your needs with the right voltage?
__________________ The 3 laws of science.... 1. If it smells bad, It's chemistry. 2. If it's mushy, It's biology. 3. If it doesn't work, It's physics. www.laserpointerforums.com A forum for disscusion of lasers and laser shows! www.laserchat.org IRC chat for laser and electronic related stuff. | |
Does the output need to be electrically isolated from the input? The current is important or at least an order of magnitude, 1ľA, 1mA, 10mA, 100mA, 1A? Does it need to be current limited for safety reasons?
__________________ I also post at the following sites: http://www.stop-microsoft.org http://www.heated-debates.com Screen name: Aloone_Jonez And http://www.silicontronics.com, same screen name as here. | ||
| another way would be a power transformer but you would have to be very lucky or rich to get one. they are also deadly
| Ramping up DC power | DSGarcia | Electronic Projects Design/Ideas/Reviews | 12 | 27th January 2007 12:24 PM |
| high power PWM project/ideas needed?? | TKS | General Electronics Chat | 7 | 28th May 2005 08:31 PM |
| high current power supply circuit. | Bondfire | General Electronics Chat | 18 | 18th April 2005 08:07 PM |
| CAR AUDIO HIGH POWER SUBWOOFER AMPLIFIER | Dumitrescu | General Electronics Chat | 5 | 1st April 2005 08:34 PM |
| Output going high on power up?!?! | 2camjohn | Micro Controllers | 5 | 23rd March 2004 07:49 PM |
