Old 16th May 2007, 02:04 AM   (permalink)
Exclamation USB wire diagram
hello im looking for a wire diagram for the usb cord that is shaped like a square w/ the rounded edges(female end i beleive).
I have a spare usb cord so the colors inside it are as follows red black green and white (and of course the bare wire for the ground).
all im trying to do to sum it up nice and simple is figure out what wire (red black green and white) correspond with the female end of the USB cable.
if ure interested in what im up to let me know and ill post it up.
korn_16_f_t_l is offline
Old 16th May 2007, 02:20 AM   (permalink)
google has the answers you seek ... a hint: usb pinout
If you don't have a planet, what good are gold bars?
want to contact me directly? gmail gordonthree
check out my project website: http://projects.dimension-x.net
Favorite numbers:
09 F9 11 02 9D 74 E3 5B D8 41 56 C5 63 56 88 C0
justDIY is offline
Old 16th May 2007, 03:04 AM   (permalink)
thats another thing i was lookin 4 the actual name of what i was up to thanx
NVM i think i get the diagram i c the numbers on each of the coresponding pins now
are all the wire inside a usb cord the same color im assuming?
but if black is ground what is the bare wire? is it a second ground?
Old 16th May 2007, 03:06 AM   (permalink)
ok i found this >>> http://pinouts.ws/usb-pinout.html if black is ground than what is the bare wire?
and so far no answer as to what color wire responds to what pins in the female end but ill keep looking
Old 16th May 2007, 03:16 AM   (permalink)
there is a signal ground (black wire), and shield (bare). a good cable should have both. a cheap cable has the red, green, white and bare, relying on the shield to also function as the signal ground.
all the colors (black, red, white, green) will be the same in any cable bearing the USB logo (assuming its not a forged logo)
Favorite numbers:
justDIY is offline
Old 16th May 2007, 03:27 AM   (permalink)
ok than where am i supposed to solder the "sheild" wire on the circuit board?
There are 4 pins (one for each of the wires) and 2 other soldered spots for the metal housing of the usb "receiver" (i can post pictures if needed)
this is just a hunch but am i supposed to solder the "sheild" wire to the same points as the metal housing?
Old 16th May 2007, 01:35 PM   (permalink)
I'm not sure what version of google you're using, but my version, the very first result, comes back with this page:
http://pinouts.ru/Slots/USB_pinout.shtml
which contains all sorts of data, including the male/female connectors and what color corresponds to what pin.
the shield wire is intended to be connected to the shielded portion of the connector (the metal shroud around the contacts)
I don't think the USB spec accepts soldering usb wires directly to a circuit board, some type of wire to board connector must be used. In the case of a one-off project, it shouldn't make much difference. just solder the shield wire to the same place you solder the black wire.
Favorite numbers:
justDIY is offline
Old 16th May 2007, 05:10 PM   (permalink)
y cant i just solder the wires directly to the board?
and if i cant than what other options do i have?
can i buy the connector (the square ones) both male and female from radio shack?
Old 16th May 2007, 05:37 PM   (permalink)
The USB specifications say a lot of things that people regularly ignore, and many of them only really matter if you want to get your device certified so you can stick a USB logo on it. for a hobbyist, it's not going to matter - adding an additional connector would not improve anything vs. a soldered connection, if anything it would be worse.
EEgeek.net
evandude is offline
Old 16th May 2007, 06:53 PM   (permalink)
instead of quoting out of context, read the whole paragraph.
Favorite numbers:
justDIY is offline
Old 17th May 2007, 07:11 AM   (permalink)
what do u mean by this i think u re saying?
i think you are saying if i replace the connector that it would make things worse but would making a direct solder connection work?
and how would replacing the connector make it worse?
still looking fr answers to those particular questions as well
Old 17th May 2007, 07:06 PM   (permalink)
Why is this so complicated? a soldered connection is going to be better than using a connector. It's pretty simple, and I don't even see why you would have to ask if a soldered connection would work - of course it will, why wouldn't it?? It's nothing but a simple electrical connection of 4 wires.
I don't intend to sound mean, but seriously, you've already received answers, and it seems like you aren't even reading them!
What kind of question is that? Is there any reason that we should try to find out for you what you can or cannot buy at your local rat shack? If you want to know if they sell USB connectors, ASK THEM!
I'm almost afraid to ask what your project actually is...
EEgeek.net
evandude is offline
Old 18th May 2007, 04:15 PM   (permalink)
no radio shack around this town for 1 i live in the middle of no where
for 2 could not find such a connector on there site
for 3
according to that or from what i am getting out of that im not supposed to solder a direct connection to the board or at least a MANUFACTURER that wants to keep the USB stamp of approval isent supposed to or somthing to that effect i was simply trying to clarify is all
a USB hard drive of mine got dropped off my desk and stopped being detected by my computer i took it apart and seen one of the pins from the actual connector on the board was broken was just going to simply solder the wires to where thay go no need to have a cocky reply or comment like that i am just trying to make shure i am understanding everything.
Old 18th May 2007, 06:19 PM   (permalink)
soldering the wires directly to the circuit board is fine for a repair
also visit www.mouser.com - no minimum order, super cheap shipping and loads of USB connectors.
Favorite numbers:
justDIY is offline
capacitance related to amperage... whiz115 General Electronics Chat 48 16th February 2007 03:16 AM
Req: simple low drop constant current source Dominique General Electronics Chat 10 9th February 2006 03:20 PM
Switcher CAD III help zachtheterrible General Electronics Chat 6 1st August 2004 02:04 AM
AC motor wiring diagram for low/high voltage - how to wire?? bill123 General Electronics Chat 2 20th May 2004 09:10 PM
