Old 14th May 2007, 01:43 PM   (permalink)
Default Electronic Ignition for bangers.
Im trying to make an electronic ignition device out of a disposable camera.
My goal is to ignite a banger that is about 5m away at the end of a wire.
Ive got it all wired up ok, but when i attach the unit to a long wire (cat5 pair) , and press the fire button, A spark occurs at the button, and the ematch at the end of the wire does not fire.
If I attach the ematch without the long wire, the ematch fires perfectly.
I have wired the capacitor up to a button and output terminals, so that when the button is pressed the output terminals receive the voltage stored in the capacitor (NB output terminals are connected directly to the capacitor via a button).
Does any one have an ideas?
thanks very much
bitem2k is offline
Old 14th May 2007, 02:05 PM   (permalink)
It sounds as though the resistance of the Cat5 wire is too high and you are losing current/energy for the spark in the wire.
Try thicker wire.
Eric
"Good enough is Perfect"
PIC tutorials:
Gramo's: www.digital-diy.net/
ericgibbs is online now
Old 14th May 2007, 02:08 PM   (permalink)
ah, is that what the problem is?
This one has been doing my head in, thanks mate.
bitem2k is offline
Old 14th May 2007, 02:40 PM   (permalink)
Electronic ignition on a sussage ?
Yummy
3v0 is online now
Old 14th May 2007, 02:59 PM   (permalink)
Try thicker wire.
Eric, your a genious!
Went to b&q, bought thicker wire, BANG!
nice one mate, thanks again.
bitem2k is offline
Old 16th May 2007, 06:44 AM   (permalink)
Why buy thicker wire? It's CAT5, and you're only using a pair, what about the other three pairs? all those wires added toether and you have the equivilant to 15 gauge wire. If you need hot and neutral it's the same as two 18 gauge wires. Per Cat5 run.
P.S. Cat3 is MUCH easier to work with and more useful to the hobbiest as it doesn't have as many turns to deal with. The extra turns in the pairs of wires on Cat5 is only useful to high speed (Greater than 10BT) communcation runs at high distances.
straight answer, har har."
Sceadwian is offline
Electronic ignition control system royal1979 Electronic Projects Design/Ideas/Reviews 4 18th May 2006 01:31 PM
Need help building a transistor electronic ignition box. grant31781 Electronic Projects Design/Ideas/Reviews 0 18th January 2006 03:10 PM
Electronic ignition (sparking) system sarang1_in Electronic Projects Design/Ideas/Reviews 8 10th November 2005 09:06 AM
frequency-voltage don't work with electronic ignition. Screech General Electronics Chat 7 16th March 2004 01:29 AM
Electronic Ignition zambo Electronic Projects Design/Ideas/Reviews 5 22nd June 2003 01:09 AM
