| View Poll Results: was the circuit usefull to you? | |||
| not at all | | 0 | 0% |
| somewhat | | 0 | 0% |
| very much | | 0 | 0% |
| excellent work | | 0 | 0% |
| Multiple Choice Poll. Voters: 0. You may not vote on this poll | |||
| hello friends ,i have developed a simple but efficient water level monitor and pump controller for OVER HEAD TANK.it has an added feature of monitoring the water level in sump or well if needed.i developed it mainly for my home,where i need to pump water from a small tank in my basement to a large OHT(over head tank). i have serached for a circuit like this for weeks,but couldnt find one.so i designed it using CMOS 4001 & 4011.for noise immunity i have used 4093 schmidt trigger IC instead of 4011(i have only a broad idea about all these jargons ,iam not sure if its appropriate)..the pin numbers are clearly shown to make design idea to practical circuit easier. The input to the logic gates can be either through a float switch or signal through a pair of conducting probes (which need to be amplified using transistors).from circuit its clear that it works on S-R latch feture of logic gates.i have provided visual output for the staus monitoring(it works in a limited way though)of tanks without extra wiring.the building cost for the circuit is less than 10 US$ including the mechanical relay and delay circuit(delayed turn -on) used with it. Out put from logic circuit is amplified using a darlington pair to drive a 100ohm 6V relay.this relay is used to switch on a delayed turn on relay circuit which switch on the main terminal to pump.(please see the pdf attchement).I used two relays for high voltage isolation as an extra protection. the probes are made of stainless steel wire (from paper clip)mounted on PVC pipes.wires are soldered to steel pins and joints made water tight with sealent adhesive.(inviting ideas for better as well as cheaper probes) After 2 months of continuous use the only one problem i have faced so far is sometimes if you switch one and off the circuit rapidly after 3 or 4 attempts it will turn on the pump regardless of water level status.but if the water level in upper tank is at it maximum or in sump if it is below lower limit it will turn off pump immediately(anyway pump will not run dry or no overflow,it fullfill the purpose) ) more details are there in the pdf file. special thanks for logism for designing this circuit.if you are into simulation of the circuit please get the logisim from website http://ozark.hendrix.edu/~burch/logisim/ i am ready to send the .*crc file if u are interested in testing and simulation.it is very easy to construct the circuit from the bmp image in the previous post. the site restrictions prevent me from uploading the file. download link to logisim http://ozark.hendrix.edu/~burch/logisim/download.html I am inviting attention of all experienced members to please go through this circuit and provide with ideas to improve the same also please point out the mistakes i made.thank you. Last edited by drkeron; 13th May 2007 at 01:21 PM. | |
| special thanks for logism for designing this circuit.if you are into simulation of the circuit please get the logisim from website http://ozark.hendrix.edu/~burch/logisim/ i am ready to send the .*crc file if u are interested in testing and simulation.it is very easy to construct the circuit from the bmp image in the previous post. the site restrictions prevent me from uploading the file. thank you. download link to logisim http://ozark.hendrix.edu/~burch/logisim/download.html | |
| in the diagram UL=UPPER TANK LOWER PROBE UU=UPPER TANK UPPER PROBE LL=LOWER TANK(SUMP)LOWER PROBE LU=LOWER TANK(SUMP) UPPER PROBE RED led turns on when lower tank is empty and remains on till water reaches upper sensor level. green led turn on when water reaches upper probe of upper tank& after that when water remains between two sensor probes in upper tank. invites methods to make circuit more immune to noise.and other possible errors.. | |
| Need Low Volume Water Pump | Noggin | General Electronics Chat | 27 | 26th June 2007 05:33 AM |
| Water Tank level reader and pump Controller | Osman | Electronic Projects Design/Ideas/Reviews | 15 | 9th May 2007 10:44 PM |
| Hot Water Circulation Pump | briguy280z | Electronic Projects Design/Ideas/Reviews | 13 | 16th February 2007 12:43 AM |
| submerging a pressure sensor under water? | AndyWatson | Electronic Projects Design/Ideas/Reviews | 14 | 26th October 2006 10:38 AM |
| A PWM Control Project for Hydrogen Generation. | chemelec | Electronic Projects Design/Ideas/Reviews | 56 | 15th June 2005 06:33 PM |
