Old 10th May 2007, 07:35 PM   (permalink)
Exclamation In need of your help Please!!
In need of your help please, trying to find a way to stop 12 volts returning back down a trigger wire, I have used a wire on a car alarm to trigger our folding mirrors which powers the indicators to flash when we disarm/arm the alarm, only thing is now when we use the indicators the mirrors fold & unfold Now if I can find something to put at the end of the alarm wires where they join the wiring loom to stop the feedback it would be a great help..
Paul.
Roytoner is offline
Old 10th May 2007, 08:02 PM   (permalink)
sounds like you need a diode.A 1n4001 from radio shack should work.
the current will only flow when the diode is correctly polarized so it will allow a positive signal to travel out a wire but not back through it.
Reality
cyb0rg777 is offline
Old 10th May 2007, 08:12 PM   (permalink)
Thanx.. I'm over the Pond in England, and went to a place called Mapplins
who soldme those http://www.maplin.co.uk/module.aspx?...&doy=10m5#spec but getting just under 2 volts feedback
Will have a look for the ones you have put me onto.
Paul.
Roytoner is offline
Old 10th May 2007, 10:30 PM   (permalink)
OK
I don't know if a different diode will solve the problem.
1n4001 is a general purpose diode.
here is the spec sheet.
http://www.fairchildsemi.com/ds/1N%2F1N4004.pdf
If I understand you ,you have your car alarm hooked to both your mirrors and indicators in parallel,but now when you flash your indicators your mirrors move.So you put a diode in series with the wire going to your siganls(so the voltage from your regular switch doesn't feed back),but you are still getting 2 volts through the alarm to the mirrors.
I can't think where the 2 volts could be coming from without a schematic.
Is this only when you flash your signals?
You might also want someone to look and make sure your mirrors aren't flashing your signals
Welcome to the forum
Reality
Old 11th May 2007, 03:45 AM   (permalink)
i would isolate the mirrors from the flashers with relays
Gaston is offline
Old 11th May 2007, 04:40 PM   (permalink)
I think you are right Gaston .It's more work but that's probably the best way.To put a relay for each signal.
Reality
Old 11th May 2007, 05:24 PM   (permalink)
Thought about that only thing is the relays would have to be live all the time which would drain the battery
cybOrg the trigger wire I am feeding for the mirrors is going to this http://cgi.ebay.co.uk/DEI-528T-PULSE...QQcmdZViewItem so onlt the mirrors are folding with the flashers.
Roytoner is offline
Old 11th May 2007, 05:59 PM   (permalink)
You'll have to make the decision how to do it. If the alarm is activating the mirrors only when you arm/disarm the alarm then the relays should not be always on.The relays are the right way to do it I think.Not that much more trouble.
Looks like a good deal on the alarm.I made one ,It's in the project section. I still need to a better sensor for it. Mine uses an infrared remote but a radio would be better because you don't need line of sight. I can always go back and change anything I want to though.
I don't see what sensor and transmitter yours is using .
Reality
