Old 10th May 2007, 11:17 AM   (permalink)
Default stable dc-dc converter
hello all,
i need a dc-dc converter for powering my tachometer.my motorcycle uses 12v battery. in normal condition voltage is 12v.but while running voltage increasing to 13-15v max.iam afraid this might burn off my chip.so is there any converter which takes 11-15v and give constantly 12v output supply?
and exactly for 5v shall i use 7805?or is there any other device which will handle this situation in a better way.
thanks
fever is offline
Old 10th May 2007, 12:26 PM   (permalink)
have a look into TRACO dcdc converters, they are simply the best
you can get ones which have a 9-18V input range and output a regulated rail dependent on the part you want
Nothing is impossible.
Styx is offline
Old 10th May 2007, 12:50 PM   (permalink)
Search the forums for threads where people have built power regulation systems to use electronics in cars. You should find it interesting.
3v0 is online now
Old 10th May 2007, 01:33 PM   (permalink)
Default remote control cicuit
I have require a remote control cicuit for toy car.
Please send me the circuit.
Rise after storm
www.board4all.cz
sundeep jangra is offline
Old 10th May 2007, 02:33 PM   (permalink)
thanks i'll do that.can u guide me with some search words...
@sanpeed
before posting any data just have a look what and where ur posting.i hope u got my point.
fever is offline
Old 10th May 2007, 03:15 PM   (permalink)
Searching here is a bit of an art.
Start with 7805, car OR auto
The 7805 is a 5V regulator.
In the search results you should find other words that can be used as keywords.
3v0 is online now
Old 11th May 2007, 03:42 AM   (permalink)
If you want to get 12V regulated from 11-15 you'll have to use a switch mode supply, linear supplies can not raise the output voltage above the input voltage without switching.
straight answer, har har."
Sceadwian is offline
Old 11th May 2007, 03:53 AM   (permalink)
He wants 5 volts.
3v0 is online now
Old 11th May 2007, 04:09 AM   (permalink)
Post
I probably should have read that last line.
Old 11th May 2007, 08:02 AM   (permalink)
well actually i want both 5v and 12v supply.
i want regulation which produce less heat.
the area where iam going to fit my tacho is around 50mm in dia with very less width.so i shld need a design which uses less number of components.and the area is fully closed,so can't think of heat generating regulators.
any more ideas regarding this issue will be appreciable.
thanks
fever is offline
Old 11th May 2007, 08:24 AM   (permalink)
Instead of the 7805, an LM2937 should be better for automotive-type applications.
- Tom Gootee
http://www.fullnet.com/~tomg/index.html
gootee is offline
Old 11th May 2007, 01:06 PM   (permalink)
Did you crash your Hayabusa a little too hard?
phalanx is offline
Old 11th May 2007, 03:18 PM   (permalink)
Do you need 12V to power the circuit ?
3v0 is online now
Old 12th May 2007, 02:19 PM   (permalink)
yes 12v to power tacho and 5v for battery voltage indicator circuit.
@gootee
LM2937 seems to be good.but can it handle rough both the lower and higher voltages according to the output voltage. imean from 10.5 to 15v input the output shld be 12v stable.
fever is offline
Old 12th May 2007, 02:34 PM   (permalink)
Why do you want 12V?
A SEPIC converter will do that.
There are ICs around that make building such a switched mode power supply easy.
http://www.google.com/search?client=...utf-8&oe=utf-8
Please also post the schematic, your circuit might run of 10.5V to 15V without modification.
Screen name: Aloone_Jonez
Hero999 is offline
24 to 12 volt Dc to Dc converter windozeuser General Electronics Chat 4 30th January 2007 03:15 AM
USB - TTL Converter samltd Electronic Projects Design/Ideas/Reviews 5 7th July 2006 10:46 PM
Monitor Converter: NTSC/PAL to VGA/SVGA scan converter NOSREME Electronic Projects Design/Ideas/Reviews 0 21st June 2005 03:46 AM
Cuk converter PWM controllers? Schneibster Electronic Projects Design/Ideas/Reviews 30 2nd May 2005 10:04 AM
Low frequency F:V converter BigM Electronic Projects Design/Ideas/Reviews 3 26th May 2004 05:54 AM
