Old 10th May 2007, 06:05 AM   (permalink)
Angry is it possible to use single supply for opamp
is it possible to use single supply for opamp i.e.. 12v alone .
My appication is to measure current , so that the output of CT is connected to my preciion rectifier , i am using 4558 opamp and +12v and -12v for supply pins. Is it possible to use only +12v, my output range should be within 5v for the range of 20 amps . So if 20 amps flows means , the output should be 5v.and if 10 amps means 2.5v should be the output , i am getiing the required output while using dual supply but while trying in single supply , i am not getting it , can anyone help me
saran is offline
Old 10th May 2007, 06:33 AM   (permalink)
The application notes are rich with examples on how to use the 4558 with a single supply (also look at application notes for 741 and LM124 and LM324).
A key concept to learn is "common mode range".
mneary is offline
Old 10th May 2007, 06:49 AM   (permalink)
Split the supply voltage in half with a voltage divider and connect the division point to the non-inverting output. A 100uF cap from the division point to ground will keep power supply noise out.
TheVictim is offline
Old 10th May 2007, 08:13 AM   (permalink)
...or use a "chopper stabilized" op-amp like the MC34071... and I believe the TL272 handles single supply easily too (though not tried it.) I'm using the MC34071 successfully in a circuit requiring 0-15v swing without the neg power supply.
P.
aussiepoof is offline
Old 10th May 2007, 08:55 AM   (permalink)
hi saran,
Can you post a sketch of the way you have connected the dual and single supply versions of your circuit.
Eric
"Good enough is Perfect"
PIC tutorials:
Gramo's: www.digital-diy.net/
ericgibbs is online now
Techniques... Making a Dual Supply from a Single Supply Ayne Electronic Projects Design/Ideas/Reviews 37 12th July 2008 12:46 PM
OP amp with PIC Single Supply Ayne Micro Controllers 6 9th February 2007 09:24 PM
Getting dual supplies from single supply bmwhittle General Electronics Chat 4 25th June 2006 12:46 AM
Single Supply vinod_sat Electronic Projects Design/Ideas/Reviews 5 16th June 2006 03:40 AM
single supply DC amplifier jmantilla General Electronics Chat 2 29th September 2004 03:05 PM
