Old 10th May 2007, 02:56 AM   (permalink)
Souper man
Default What exactly is a photodiode?
I am looking for a in depth answer to what a photodiode is and where can I get them.
Remember, photoDIODE, not Photoresistor
Old 10th May 2007, 03:05 AM   (permalink)
It's a diode... like any other diode, although with a transparent package. Sometimes the external package material is tuned for a specific spectrum, but EVERY PN junction exhibits a photo electric effect. Light applied to the junction will produce current through it. The photons knock around the free electrons. Any LED will exhibit a photo diode effect. (Just put one on a scope and shine a light at it) Basic semi conductor physics. Also little known, is all semi conductor junction emit some form of light =) One of the reasons why they come in opaque packages.
straight answer, har har."
Sceadwian is offline
Old 10th May 2007, 07:50 AM   (permalink)
.... so if you connect a photodiode in series with a resistor and connect the whole lot accross a dc supply, the current through the resistor (and therefore the voltage accross it) will vary with the light intensity.
With specially made diodes light variations in the MHz region can be monitored. I have used PIN photodiodes to detect laser pulses only about 10ns duration.
dch222 is offline
Old 10th May 2007, 07:51 PM   (permalink)
Souper man
still, where can i get them?
Also, by hooking them up to the base of a NPN transistor, could I use them for a light following robot?
Old 11th May 2007, 05:07 AM   (permalink)
A Photo-diode can be used in one of two ways:
1) If it is reverse-biased then it leaks a small current when it is exposed to light or IR. The reverse-bias voltage reduces its capacitance so it is fast.
2) If it has no bias voltage then it generates a small forward voltage when it is exposed to light or IR. It is very sensitive.
audioguru is online now
Old 12th May 2007, 01:09 AM   (permalink)
Any generic LED can be used as a photo diode. But you need relativly sensative circuits to really use them.
Old 12th May 2007, 02:37 PM   (permalink)
Well I've managed to use a 400nm violet diode to detect 407nm light from a black light using a multimeter so I wouldn't agree, you just need a simply high impedance amplifier.
Screen name: Aloone_Jonez
Hero999 is online now
Old 12th May 2007, 09:16 PM   (permalink)
Souper man
still i dont get how to use them and where to get them!!!
Measuring Current recieved from a Photodiode crush Electronic Projects Design/Ideas/Reviews 3 9th November 2006 06:39 PM
How to choose the right photodiode for my application Electrolinux Electronic Projects Design/Ideas/Reviews 2 4th September 2006 06:46 PM
Peak Forward DC Current of photodiode haku87 General Electronics Chat 34 17th April 2006 04:35 PM
Photodiode lights a LED Lightbar Uman Electronic Projects Design/Ideas/Reviews 6 17th November 2004 04:34 AM
Looking for IR photodiode (or phototransistor) - in picture CocaCola Datasheet/Parts Requests 1 29th August 2004 09:06 PM
