Old 8th May 2007, 06:06 AM   (permalink)
Default Eagle Library
Can someone help me find eagle library for ATMega88 chip?
bababui is offline
Old 8th May 2007, 06:23 AM   (permalink)
Did you google for it, Did you huh, Did you GOOGLE ?
I found this lib which claims to have it.
Free AVR Lib for Eagle
3v0 is online now
Old 8th May 2007, 07:14 AM   (permalink)
Yes I googled and got the same link, however, I can only find PDF spec sheets there. I didn't find eagle library file. Maybe you can point it out for me?
bababui is offline
Old 8th May 2007, 07:43 AM   (permalink)
Sorry/Bummer, I did not see it either, I did not translate the site and my German is very poor. If you can find it there post it here. Others will be looking for it.
It is not too hard to create the part in Eagle esp if you copy and modify existing parts to do so. There are tutorials.
3v0 is online now
Old 8th May 2007, 01:24 PM   (permalink)
just pick any atmel chip with the same pin count ... if atmel are anything like microchip, the same size chips in a series usually have the same pinouts. eagle doesn't care you're using the wrong chip, and it won't effect the outcome of your pcb fabrication either
If you don't have a planet, what good are gold bars?
want to contact me directly? gmail gordonthree
check out my project website: http://projects.dimension-x.net
Favorite numbers:
09 F9 11 02 9D 74 E3 5B D8 41 56 C5 63 56 88 C0
justDIY is offline
Old 8th May 2007, 01:39 PM   (permalink)
Or create your own library part, all you have to do is take a standard chip of the same form factor and edit the PIN identification to match the PDF sheet of your AVR.
straight answer, har har."
Sceadwian is offline
Old 8th May 2007, 08:29 PM   (permalink)
but do make a copy first...
philba is offline
Old 8th May 2007, 09:10 PM   (permalink)
HALT! don't start making one yourself just jet. I had the exact same problem 6 days ago. then I did search google, but probably a bit more...
google "atmega88 eagle library"
First result: http://www.avrfreaks.net/index.php?m...ol&item_id=479
dl here: http://www.embedit.de/content/view/45/26/
Need Help?
Press F1
If that doesn\'t help you, ask me... I might know better.
bloody-orc is offline
Old 8th May 2007, 09:40 PM   (permalink)
I found that page but missed the download link.
Good Job.
3v0 is online now
Old 8th May 2007, 11:08 PM   (permalink)
Do you have all of the Atmel libraries from CadsoftUSA?
mneary is offline
Old 9th May 2007, 03:26 AM   (permalink)
if you're going to go to the trouble of making your own part, I recommend using the copy and paste function, and making several diagrams for the same part.
for example, some pics have lots of multiplexed functions on each pin. instead of trying to type all those functions in on a single diagram, and ending up with a huge box full of abbreviations, it's better to break it down like 18f4550 analog, 18f4550 usb + spp, and so on ... then you don't have all the clutter of those functions which have no bearing on your application
Favorite numbers:
justDIY is offline
Old 9th May 2007, 05:04 AM   (permalink)
Originally Posted by justDIY
if you're going to go to the trouble of making your own part... it's better to break it down like 18f4550 analog, 18f4550 usb + spp, and so on ..
Good idea. You can also make a symbol with a pin arrangement that works best for the schematic you are working on. A view of the chip as you are using it.
The attached example shows a PIC16F886 where I grouped the pins used for a 8 bit LCD on one side. It makes for a much neater schematic. Perhaps a bit anal but why not strut your stuff.
EDIT: The PIC to LCD pin assignments were made to reduce the number of vias on the board. It makes the LCD driver code a bit interesting but you only have to write it once.
3v0 is online now
Old 9th May 2007, 09:34 AM   (permalink)
3v0 what are you doing? why are you using so many pins to control an LCD? you only need the first 4 bits of the LCD control unit. all the libraries have been written that way and most of the commercial applications are done so. no-one uses 8 bit data on character LCDs anymore . and then you can fit the whole LCD into one port of the PIC wasting much less pins.
connection like that: http://www.oopic.com/lcd.gif
a little OT, but i just had to say that ans save you a lot of trouble hopefully.
Need Help?
Press F1
Old 9th May 2007, 01:56 PM   (permalink)
Originally Posted by bloody-orc
3v0 what are you doing? why are you using so many pins to control an LCD?...
The point of my post was to show that you could create Eagle symbols that make you schematic easier to read. It was not about the circuit which I think I have talked about in another post.
This is a general purpose controller with a few IO bits and a $1.50 LCD display hardwired for a 8 bit parallel data bus. Using a 28 pin PIC reduces the part count. The board is the same lenght as the LCD which can be mounted with angle brackets.
Some people have cut a trace on these boards to put them in I2C mode but it is a delicate operation. On the boards I have the pad to be cut is mostly under the epoxy.
3v0 is online now
How to properly do PCB edge connections in Eagle? toodles Electronic Projects Design/Ideas/Reviews 2 10th April 2007 11:36 PM
MC33886DH Eagle library? anybody? raitl General Electronics Chat 1 4th August 2006 09:53 AM
Microchip library for eagle nclark Micro Controllers 2 14th November 2005 08:12 PM
Dallas - Maxim Library for Eagle Robertino General Electronics Chat 3 24th November 2003 09:16 AM
eagle pcb 4.09r2e -library vicky Electronic Projects Design/Ideas/Reviews 1 11th May 2003 12:17 AM
