| I am using a micro stamp (BS2) to monitor an RS-232 input and then perform certain functions based on the input data received. It never needs to transmit serial data. The circuit does have a push button that will provide the +V input as an output (through a 10K resistor) when pressed. I only have 5 pins that I can use (on an M12 connector). The entire circuit will be encapsulated in a potting compount. During normal operations, this is enough for +V, Rx, Gnd, and the pushbutton output. However, I would also like to be able to reprogram the processor which requires the Tx line and the DTR (ATN) lines--which makes 6. Because I only have 5 pins available on my connector, I would like the pushbutton output line to serve double duty and be used as the RS-232 Tx line during programming (and I will not press the button during this time). How do I protect the idle RS-232 output from any effects from +V being applied by the pushbutton. I at first thought of using a diode but remembered that RS-232 generates +/- 12 volts and so that would not work. I would have two different cables--the normal cable (no pin 5) and a special programming cable (that has the DTR signal connected to pin 5). Of course, pin 2 will be common to the pushbutton and the Tx line respectively. One more thing... I have almost no room on the board. I.E., no room for a RS-232 transceiver dip. Any ideas? Thanks, Dale | |
| It makes more sense to piggy back the push button on the RX line. Set it up so that pushing it generates a break condition which you should be able to detect in the status register for the UART. Build a 2nd board with the RS232 level shifter on it.
__________________ search engine for electronic partsJunebug USB PIC programmer kit., USB Bit Wacker, 3v0's Homepage The 15 Minute Printed Circuit Board! (+drill time) | |
| Need advice about this AC Line Current Detector | Avocado | Electronic Projects Design/Ideas/Reviews | 6 | 21st March 2008 06:37 PM |
| DS1302 with PIC16f877 program | RasCreationKing | Micro Controllers | 28 | 3rd May 2007 01:03 PM |
| QBasic Serial Port Control | DigiTan | Micro Controllers | 3 | 6th January 2006 12:32 AM |
| how to transmit or remotely view video over telephone line | abel2b | Electronic Projects Design/Ideas/Reviews | 8 | 8th July 2005 07:05 PM |
| 2 line telephone patcher / switcher .. help please | rca507 | Electronic Projects Design/Ideas/Reviews | 1 | 20th February 2004 05:19 AM |
