| Anyony know what these things are made with. They cost $25.00 and I'd like a Dc-DC voltage regulator but for a hole lot less $$$. The AnyVolt Mini is a miniature step up / step down 0.5A switching DC-DC converter. The output is adjustable from 1.25 to 14V. http://www.dimensionengineering.com/...nyVoltMini.pdf http://www.dimensionengineering.com/AnyVoltMini.htm Any suggestions on how to build one! I'd like to be able to use a USB port to run different devices, maybe even charge batteries... | |
| It says on the main page that these devices use the SEPIC DC-DC converter topology. Just type "SEPIC Converter" into google and you'll get a good start. there is alot of information as well as schematics about it on the web. how much current do you need? USB provides a useful amount of power but it might not be enough for your particular application. | |
| What current do you require?
| the dimension engineering products are very inexpensive for what they do. look through the digikey or mouser catalogs for preassembled dc-dc converters, most start at $50 and go up from there. if you specify your input and output voltages and current, folks might be able to suggest a better fitting product. usually boost converters (sepic or otherwise) are limited on output current due to limited input current and input current handling.
__________________ If you don't have a planet, what good are gold bars? want to contact me directly? gmail gordonthree check out my project website: http://projects.dimension-x.net Favorite numbers: 09 F9 11 02 9D 74 E3 5B D8 41 56 C5 63 56 88 C0 | |
| The current necessary would be to power a 1.5 in X 1.5 in CPU fan, aprox 100mA-150mA? $50 is far too much! | |
| 24 to 12 volt Dc to Dc converter | windozeuser | General Electronics Chat | 4 | 30th January 2007 03:15 AM |
| Universal Interface Converter | chintan_jagani | Electronic Projects Design/Ideas/Reviews | 7 | 27th September 2006 02:17 PM |
| 12V DC to 24V AC mini converter for Xmas lights | Jules | Electronic Projects Design/Ideas/Reviews | 9 | 9th December 2005 03:48 PM |
