Old 5th May 2007, 11:30 PM   (permalink)
Default DC power through Var. AC Xformer -> Wart
The title is sort of vague, so I'll specify: Will a wall wart still produce a stable, usable voltage if it's plugged into a variable AC transformer? I've noticed that if I put 60VAC into the wart, it outputs half of it's rated voltage output. Is this power source still relatively clean?
And another question, if anyone can help me with this one: What is a practical purpose of using a Buffer chip? Is it merely useful as a replacement to a row of diodes in certain computer applications? (A ZX81 I assembled used a row of diodes in series with the keyboard connection.)
Thanks muchly, everyone!
Feels good, man.
ArtemisGoldfish is offline
Old 6th May 2007, 02:24 AM   (permalink)
Buffers are basically seperators from high impedance signals to low impedance ones. A good opamp circuit can eliminate any loading effects on the sampled signal used as a drive, they can also easily filter.
Yes the power source is still relativly clean so long as the supplied waveform is still a sine wave. If your variable AC transformer is something like an auto transformer, you're fine.
straight answer, har har."
Sceadwian is offline
Old 6th May 2007, 02:45 AM   (permalink)
Well, if it helps any, it looks like a Superior Electric Co. PowerStat, and I can feel it buzzing when I turn it on. It's kind of old, since the plug on it is ungrounded.
Feels good, man.
Old 6th May 2007, 09:38 PM   (permalink)
Sounds like something every hobbyist should have, I've seen a few but they're all a bit expensive. Do keep in mind though that you're introducing high frequency noise (in relation to the normal 50-60hz mains frequency) from the contact bounce when you adjust it so you may get odd happenings on any circuit you have plugged into it if you don't add some bypass capacitors to bleed off the noise, wallwarts were meant to filter 50-60hz ripple. You could always check the output on a scope and see what the noise really was, but it shouldn't be too big of an issue.
DC Power Supply PCB pixnum Electronic Projects Design/Ideas/Reviews 42 5th August 2007 07:33 PM
DC power supply from LAN point mdanh2002 Chit-Chat 8 11th May 2007 03:18 PM
AC adapter for a lab power supply Souper man Electronic Projects Design/Ideas/Reviews 9 12th April 2007 05:56 PM
DC IN, DC out power supply testingpurpose General Electronics Chat 6 23rd January 2007 10:05 AM
[help] Power consumption issue on bullet counter project * Lanzer Electronic Projects Design/Ideas/Reviews 13 26th August 2005 07:06 AM
