Old 5th May 2007, 12:47 AM   (permalink)
Default ON/OFF pushbutton circuit for battery powered device
Not sure if this forum is the best place for this post, just let me know if I should move it
I am making a PIC based device that uses +5V for PIC and +3.3V for some other circuits.
Power coming from two AA batteries converted to +5V and +3.3V using TPS60120 and TPS60140.
What I need is ON/OFF switch using one (on/off) or two (on and off) pushbuttons.
Slider on/off switch is not an option, I need pushbuttons
Something like:
- ON button brings power to PIC,
- PIC bypasses ON switch, seals it
- PIC will shut device down once OFF button held for 5 seconds or no activity for a 2 minutes.
It would be better if I can make it with one button.
Can TPS's enable input be used?
Any other ICs?
Battery gives only 1.8-2.6V and any voltage drop is costly.
Andy_123 is offline
Old 5th May 2007, 01:09 AM   (permalink)
Don't no much about PIC, and just a beginner with AVR, but seems like this could be done with an plain SPST pushbutton, SLEEP MODE, and a Pin Change Interupt. Not sure if your PIC has these features, but $1.16, 8-pin ATTiny13L does, and current draw in Power-Down sleep mode is very low, <0.1 uA at 1.8 volts.
HarveyH42 is offline
Old 5th May 2007, 01:13 AM   (permalink)
I was looking at sleep mode, but I don't really want to keep these charge pumps running. At least I need to keep +5V running and this will drain battery I guess...
Andy_123 is offline
Old 5th May 2007, 01:57 AM   (permalink)
I probably needs something like this
http://www.linear.com/pc/productDeta...3,C1144,P10330
or event better, because no extra ICs needed:
http://www.maxim-ic.com/appnotes.cfm/an_pk/3283
I can implement this one with TPS60140 and 2 diodes instead of "OR"
Andy_123 is offline
need a circuit for control a relay on/off from a PC RS232 kingsz1 General Electronics Chat 16 2nd September 2004 06:51 PM
start/stop watch circuit bd13 Electronic Projects Design/Ideas/Reviews 2 21st March 2004 04:07 AM
Newbie building a USB powered relay circuit damirksi Electronic Projects Design/Ideas/Reviews 1 16th February 2004 09:42 PM
Circuit functioning very strange. Why? Cyclone Electronic Projects Design/Ideas/Reviews 12 4th November 2003 01:31 AM
Help with sounds alarm after 30sec w/ battery saver circuit DaKandEKid Electronic Projects Design/Ideas/Reviews 2 1st September 2003 09:31 PM
