| I am a newbie and am fired up to learn how to create simple motorized mechanisms and sounds that are attached to a quartz clock movement. I would like to trigger the mechanisms per hour, half hour, etc. Can anyone help point me in the right direction? Books or kits? Parts to use etc.? Thanks a bunch in advance and I will update you all with my progress! | |
| More questions then answers. Quote:
Does it have any outputs/alarms that you could use to trigger/start circuits that drive motors ? If you must use a clock movement you will need to detect the hand position(s) using some soft of frictionless switch(s). Can you scrap the clock movement and use a microcontroller (with a crystal) to keep the time, start the gadgets, and move the clock hands?
__________________ search engine for electronic partsJunebug USB PIC programmer kit., USB Bit Wacker, 3v0's Homepage The 15 Minute Printed Circuit Board! (+drill time) | ||
| Thanks for the reply. I simply do not know enough about the mechanisms of a quartz movement, let alone a microprocessor. Sounds like I can use the alarm as an output to start the animation. Can it support multiple animations? As for the power requirement, the moving parts will be made of wood and metal, and can be up to 1.5 feet from the quartz. The microprocessor option sounds infinitely more exciting. Can I add as many moving parts as I wish, and as many motors necessary to run them? Looks like I need an eletronic start kit :-) | |
Start with simple things like blinking a led. If you can do that you can power a relay that can run a motor that can do most anything... It will be a lot of work but if it is your sort of thing it will be fun. Start by reading Newcomers, please read! (PIC regarded) Upd. 0xD in the Micro Controller forum. There are quite a few people here that will provide help to most anyone who is willing to make the effort.
__________________ search engine for electronic partsJunebug USB PIC programmer kit., USB Bit Wacker, 3v0's Homepage The 15 Minute Printed Circuit Board! (+drill time) Last edited by 3v0; 6th May 2007 at 09:40 PM. | ||
| They (microcontrollers) are completely worth the learning curve
__________________ Spency. PIC Micro's - Your mind is the limit PIC's and interfacing with other devices - a PIC Basic Guide @ digital-diy.net | |
| Thank you both for your help. I'll get busy. | |
| Check out Suman's Mount(bottom of page) It's motorized drive from a quartz clock. http://astronomylinks.com/astrophotography/equipment/ | |
| Problem with LCD code? | spondootre | Micro Controllers | 15 | 29th April 2008 10:15 AM |
| Electro Mechanical Clock Chime | oliverb | Electronic Projects Design/Ideas/Reviews | 37 | 25th February 2007 06:44 AM |
| mechanical quartz clock schematic | bdcroucher | General Electronics Chat | 5 | 21st October 2006 10:15 PM |
| Help me on basketball's game clock and shot clock! | syaw_007 | Electronic Projects Design/Ideas/Reviews | 1 | 6th September 2004 10:50 PM |
| Quartz Analogue Clock from 80's model car | Zarniwoop | Electronic Projects Design/Ideas/Reviews | 2 | 10th November 2003 02:27 AM |
