Old 2nd May 2007, 06:12 PM   (permalink)
Souper man
Red face Rechargeable AA Energizer battery
I am a little confused, although the answer may be simple:
Is a AA rechargeable Energizer green battery have 2.5 amps? this seems like alot please help me out
Old 2nd May 2007, 07:25 PM   (permalink)
Like he said \/
TrevorP is offline
Old 2nd May 2007, 07:28 PM   (permalink)
2.5 amp-hrs is a reasonable capacity expectation for a rechargeable AA.
That means it can put out half an amp for 5 hrs, or one amp for 2.5 hrs.
Oznog is offline
Old 3rd May 2007, 08:23 AM   (permalink)
Or 2.5 amps for one hour
picbits is offline
Old 3rd May 2007, 08:30 AM   (permalink)
hi souper
This site has some battery discharge data that may help.
http://www.powerstream.com/AA-tests.htm
Eric
"Good enough is Perfect"
PIC tutorials:
Gramo's: www.digital-diy.net/
ericgibbs is online now
Old 3rd May 2007, 01:36 PM   (permalink)
Since you are talking about an Energizer battery then why not see its datasheet on Energizer's website?
It works pretty well with a current up to 2.5A but is not so good at 5A.
audioguru is online now
Old 3rd May 2007, 11:10 PM   (permalink)
Souper man
Ok let me get this straight:
My robot that I am using it for (A line following robot called linebot, which is a original name i know) uses about 200mA. So, could I run my 9.6 volt (1.2 x 8 = 9.6) 20 aH (2.5 x 8 = 20) Battery pack for 100 hours? Wouldnt it just use all 20 amps, or would it use the mA it needs?
Old 3rd May 2007, 11:27 PM   (permalink)
If you use 2500mA cells in series, then the battery has a 2500mAh rating.
At 200mA the battery will last for 2500/200= 12.5 hours.
A circuit takes only as much current as it needs. Your robot will use a low current when it is stopped and will use a high current when it is accellerating up a hill.
Old 4th May 2007, 12:55 AM   (permalink)
Souper man
thanks alot
lead acid rechargeable battery problem miaomiaooh General Electronics Chat 16 14th January 2007 09:18 AM
A rechargeable battery for desk top computer system peace Electronic Projects Design/Ideas/Reviews 1 5th August 2006 02:16 PM
Replacing a Battery DirtyLude Electronic Projects Design/Ideas/Reviews 5 13th July 2005 01:55 PM
Connect Battery and PSU at same time...? grrr_arrghh General Electronics Chat 3 10th July 2004 12:20 AM
max current on rechargeable PP3 battery ? defcon31 General Electronics Chat 7 26th January 2004 09:52 AM
