| My first post/questions. I'm hoping to reduce RF noise in the house by replacing some very noisy switch mode power supplies which power a Soekris net4801 server and a USB HDD caddy. I'd also like to power an adsl modem (15V) and an ethernet switch (7.5V) from the same supply, but as that would require some extra effort, and their 'wall warts' aren't too noisy, I may leave that until later. I've found an old AT form factor power supply, which powers up with a small load on the 5V output. The RF noise is much lower from this. Is it ok to just connect them across the suitable outputs? Should I 'decouple' the feed to each device? Should I put a fuse in line to each device?. What about a 'crowbar' circuit? Lastly; should I devise some means to wait for the 'power good' signal from the PSU? (could the power before the signal damage the devices connected?) Thanks for a great forum. John. | |
Once you get by that dilemma, then you can answer your other questions. If you want to go with a linear supply, it will be heavy and not as efficient. The old AT supply has output protection and regulation. To fuse is really up to you. How critical are the devices being powered. All in all, I'm confused as to what the real problem here is...
__________________ "Everything that is done in the world is done by hope." -Martin Luther "There are two ways to live your life. One is as though nothing is a miracle. The other is as though everything is a miracle."-Albert Einstein | ||
| CPU PSU and 14.4V drill | Hank Fletcher | General Electronics Chat | 2 | 30th April 2007 06:48 AM |
| disturbing Sony devices (TV, VCR, etc.) with my own project | krompo | Micro Controllers | 9 | 30th August 2005 02:21 PM |
| What are special ICD devices? | MathGeek | Micro Controllers | 10 | 23rd August 2005 02:15 AM |
| PIC and multiple serial devices | Oznog | Micro Controllers | 14 | 26th May 2005 09:18 AM |
| Multiple devices controlled at once on one parallel port | Kerri Ann | Electronic Projects Design/Ideas/Reviews | 0 | 18th February 2005 11:52 AM |
