Old 30th April 2007, 09:37 AM   (permalink)
Default two wheel balanced moving cart ( need help)
hi everyone,
I need help with this project which is a cart with only two wheels but it should be balanced, which means if it fill down on one side front or rear it should re balance it self again. for this i thought that i can use a zero crossing detector which will know if it fill on one side it trigger the comparator to compare with the zero refrence but i'm not sure that it will work efficentlly.
It also should be moving forward and backward, right and left.
do u got any ideas??
please help me i got only month to implement that idea and i'm so bussy that i'm working 12 our night shift 6 days a week.
jalal is offline
Old 30th April 2007, 09:46 AM   (permalink)
hi jalal
You can buy 'tilt' sensors, that can be set to switch at a preset angle [ by positioning the tilt sensor]
Put one at each edge of the cart, so if the cart tilts towards that edge the tilt switch closes.
How do you plan to correct the tilt of cart, when you have detected the tilt??
Eric
"Good enough is Perfect"
PIC tutorials:
Gramo's: www.digital-diy.net/
ericgibbs is offline
Old 30th April 2007, 08:28 PM   (permalink)
Dean Kamen solved this problem in the Segway. It is not a simple problem.
Ron (aka Rube)
Roff is offline
Old 1st May 2007, 01:31 AM   (permalink)
You need really high speed control loops and high update rate sensors to do something like that, very high torque motors as well. I've seen mpeg's of a guy on the net that built his own segway using the same principles (though not nearly as elegent)
straight answer, har har."
Sceadwian is offline
Old 2nd May 2007, 01:32 PM   (permalink)
when the professor gave me this idea he told me that it is easy to be done and i'm sure he knows the right circuit for this project. it must have an easier solution.
thanks anyway
if i got an easier answer of this problem i'll try and then i'll keep hear so you can make sure if its ok or not.
jalal is offline
Old 2nd May 2007, 03:16 PM   (permalink)
Do a Google search on "balancing robot". You can probably steal someone else's design. You might not learn much, but you'll get a good grade, unless your professor also knows about Google.
Ron (aka Rube)
Roff is offline
Old 3rd May 2007, 04:09 PM   (permalink)
Hi
Try to watch the following video from Engineering TV web site
1- http://engineeringtv.com/blogs/etv/a...-robots-i.aspx
2- http://engineeringtv.com/blogs/etv/a...robots-ii.aspx
kamdy is offline
Old 3rd May 2007, 05:49 PM   (permalink)
Have you ever worked with an inverted pendulum in your control classes before? If you haven't, you might not be able to get your project done in time...
dknguyen is offline
Old 18th May 2007, 10:12 AM   (permalink)
Is there any reference i can go back to about the inverted pendulum
just to get the general idea of it
jalal is offline
Old 18th May 2007, 01:31 PM   (permalink)
Default Balancing Robot
I've seen designs that eliminate gyros and accelerometers by aiming an infrared distance sensor at the ground from the top of the robot. It only works on flat ground.
Here's a design that uses an ultrasonic sensor controlled by a Basic Stamp:
http://forums.parallax.com/forums/de...?f=21&m=162898
bobledoux is offline
Old 18th May 2007, 04:01 PM   (permalink)
Uh, yes, GOOGLE, which should almost always be your first reference.
EEgeek.net
evandude is offline
Old 19th May 2007, 01:04 AM   (permalink)
Wikipedia is a good start for 99% of electronics topics.
Motor Sizing For Moving Robots dknguyen Electronic Theory 6 25th April 2007 11:44 PM
Advanced Race Car Steering Wheel Controller dj_ash1983 Electronic Projects Design/Ideas/Reviews 3 9th February 2007 02:57 PM
wheel mouse samarsingla General Electronics Chat 28 9th July 2006 04:49 PM
PC steering wheel hack woogoo General Electronics Chat 2 29th April 2005 07:09 PM
okay project idea: shopping cart and radio car mr. mister Electronic Projects Design/Ideas/Reviews 5 6th August 2004 06:09 PM
