Old 28th April 2007, 11:28 PM   (permalink)
Post Radio Control Demystification Anyone?
Hi all,
Ive been researching Radio Frequency and Radio Control for the last couple of weeks and am looking for a couple answers and Opinions not found on google.
Basically I just finished making a PIC1684a door locker/unlocker...
The project was made so that I can simply and remotely trigger the circuit to lock/unlock my door..
Right now, it is setup in the following way:
-The PIC sits in an endless loop waiting for the trigger...
-The trigger is a light detecting comparator circuit made for a LM358 opamp
-Light is shone on the photo transistor and the comparator threshold voltage drops.. making the opamp output go HIGH..
-This HIGH signal is picked up by the PIC which goes into another endless loop, which waits until the light is shone away.. once this occurs the PIC pulses one of its outputs 60 times.. turning a small stepper motor a little over90degrees (I found that exactly 90degree (50 steps) sometimes does not turn the locking mechanism enough)
-The Pulses are turned into 1.8 degree steps and driven by a BIPOLAR stepper motor driving chip, the MC3479.
-The lock is now either open or close.
-The PIC then toggles an output, which changes the direction for the next turn.
-The PIC also turns the MC3479 off via NPN transistor.. saving power and allowing the stepper motor to turn freely (Ie when the knob is turned)
The above information is to give others idea..
Now then, Questions:
1) The photo transistor is easily falsely triggered by ambient light.. I REALLY REALLY want to work with radio control..
Can I make a radio (FM?) transmitter and Reciever that can control 1!!! PIC input On and off?
NO MODULATION NEEDED!! ALL ITS GOTTA SAY IS " HEY PIC OUPUT TURN THE HECK ON" or "HEY PIC OUTPUT TURN THE HECK OFF"
OR
Do I NEED to purchase premade transmitters and recievers?
Like these?
I live in Canada.. as most of you no from my last thread
Can you recommend a CHEAP place or website to buy these?
2) Can I put the PIC into SLEEP then WAKE it up each time it is subjected to the trigger? Will this save any power at all? Do I need to use a Interupt to wake it up?
Thanks alot,
"Stick around" - Arnold Schwarzenegger in The Predator after impaling a soldier to a wood post
9vDC Guitar Pedal PSU
PIC16F84a Game Module
Peter_wadley is offline
Old 28th April 2007, 11:33 PM   (permalink)
You NEED modulation, and to do the job properly - check my tutorials which have both RF and IR examples which would both do your requirement perfectly.
Basically you've designed it completely wrongly, with no regard for how it should be done - if you want to use IR (and it's perfectly fine), use 38KHz modulation and digital coding, and a standard IR receiver IC.
Old 28th April 2007, 11:40 PM   (permalink)
http://www.abacomdirect.com/
These are made in Toronto.
Maybe you could go buy them in person and get some free advice.
Brevor is offline
Old 28th April 2007, 11:43 PM   (permalink)
Considering I didnt even know what a transistor was 3 months ago, and that is not at all an exaggeration.. I think i am doing a pretty damn good job on designing circuits..
Are you saying the ENTIRE circuit is completely wrong ? It opens the door without me having to get up.. its a success in my opinion..
The only area that is weak is the communications...
Which IR IC should I get?
Where can I get the IC reciever? My electonics store does not carry any.
Do you think this will work? The only thing that conserns me is the inductor.
Old 28th April 2007, 11:55 PM   (permalink)
Thanks Brevor I will contact this company.. There prices are very high however.
Nigel, I just looked up your IR tutorial again and remember why I didnt go through with it -the code seems VERY tedious/lengthy just to turn a PIC input on and off.
Old 29th April 2007, 12:03 AM   (permalink)
Peter. IR encoding can be as simple as starting a PIC's PWM output at the desired frequency (around 38khz) and then turning the PWM output on and off to modulate, which can be done with a 2nd timer. A detector can be a simple filter (no pic needed) fed directly into a digital I/O line of any type of device. The bulk of the code on Nigel's site is for the communication protocol and LCD interface.
straight answer, har har."
Sceadwian is offline
Old 29th April 2007, 12:28 AM   (permalink)
You did not state the range you were looking for.
I have been using both RC micro cars and remote door bells as cheap and effective remote controls for digital cameras. There are no reason why they could not control a PIC. Take a look:
http://www.pbase.com/sinoline/rf_rem...ntrol_for_d7xx
http://www.pbase.com/sinoline/rf_remote_new_model
You are doing fantastic in you electronic endeavor; there are usually many ways to achieve a certain goal and usually not any one is the absolute best, so don't let any of the rude so called experts discourage you!
Rolf is offline
Old 29th April 2007, 01:14 AM   (permalink)
Thanks for the encouragement Rolf!
You have a great collection of electronics! Thanks for sharing them!
I completely agree with that.
Here are some pictures of the circuit..
Keep in mind that it was made from scratch today and is no where near complete.
I will repost pics after I sort out this communication problem aswell as make the PCB and placed it in its enclosure.
Pictures:
I used steel strapping to keep the motor in place.
The black piece used to attach the blank shaft of the stepper to the locking mechanism was made out of the same steel strapping .. i used black shrink wrap to ensure the strapping does not scratch the door knob.
The black piece was then bonded using Lepage Expoxy #11
Top chip = LM358n
Middle = PIC16f84a
Bottom = MC3478
Stepper motor = bipolar
Power supply is 12v wall wart.
You can see the photo transistor at top.. it is clear.
The red LED turns on when photo transistor is subjected to light. (Just an indicator)
The green LED lets you know when the door is unlocked.
I guess radio control would be over kill for this.. the range needed is at most 20 ft.
I would use like to use IR but the modulation is throwing me off.
Old 29th April 2007, 05:17 AM   (permalink)
Ok,
Nigel, after re-re-reading your IR tutorial, it doesnt seem that difficult at all.
Constuctive feedback: Possibly consider making the FIRST sample code just the bare bones of IR communication.. it makes it all the much harder decipher what is LCD code and what is IR code...
From what I have read at your site and others..
I need:
This
I just had one but I couldnt figure out the pinout, so I chucked it I went back to my electronics store but of course the owner didnt even know how to hook it up
The source, canadas equivilent to Radio Shack, doesnt seem to carry them either..
On monday I think I will go back to the store and ask the owner to call the head office for the pin out then buy another one..
So, if this is right :|, I will hook one of the three legs to GND and one to 3.3 or 5v (which?) I think I may have burned the other out with 5v..
ok the part I dont really get..
To send the modulated data.. I just use a PIC to blink an IR LED off and on at 38 000 times per second - right? :|
Then to code the 38khz signal I just turn it off (0) and on (1) for a certain amount of time.. right? am i getting this?
Then the 38khz detector will capture this from the IR LED and send it on its data line into ANOTHER PIC which will some how decode it into 1's and 0's then take action when the code is correct?
Old 29th April 2007, 07:49 AM   (permalink)
Those kinds of modules are usually 5 volt. It's just like using a photo transistor except it only signals 1 or 0 when it detects the modulated light, which makes it harder to false trigger from ambient lightning. A non modulated IR receiver will trigger on all manner of light sources. They work exceptionally well and are very simple for on and off, or low bit rate data transfer, they're usually limited to between 2400 and 9600 baud. The center frequency has quiet a bit of leeway.
Old 29th April 2007, 06:36 PM   (permalink)
Thanks Sceadwian,
Does anyone know the range of one of these?
Old 29th April 2007, 07:35 PM   (permalink)
Depends on ambient light conditions, while the modulation makes them more or less immune to ambient light falsly triggering them it doesn't eliminate the 'DC bias' that it introduces. If the IR LED isn't bright enough to overcome the ambient conditions the receiver won't be able to detect it even if it is modulated properly. So range is pretty much limited to how big an IR array you put on the transmitter and line of site, an IR laser could probably trigger one at a distance of a few thousand feet at night.
Old 29th April 2007, 09:26 PM   (permalink)
Ok,
It's not, it's just the initial idea which is hard to understand.
The tutorials follow on, the LCD code is explained earlier.
I need:
This
That looks fine!.
Read and understand my tutorial, you need to understand the basic premise of how it works - the 38KHz is really a layer above what you need to understand, the receiver strips it off.
Old 29th April 2007, 11:02 PM   (permalink)
I just read throught this .PDF
Its from the Microchip site.
I think I understand IR Modulation now.
But just so I am sure..
The 38khz carrier signal is used so the reciever module can filter out ambient light and ambient signals right?
How sensitive is the module regarding carrier frequency? would it work properly if the carrier was lets say 32 khz (random number)
and lastly,
The 38khz module will only respond to a signal that is running at 38khz.. when this requirement is met the module outputs digital signals (0's and 1's) which the pic can directly decode. right?
Thanks again for helping out.
PW
Old 30th April 2007, 07:42 AM   (permalink)
38khz is approximate, it really depends on the number of poles and type of filter the module uses. The closer you are to the frequency the module uses though the better your results are gonig to be. How bad they are as you stray is really module and environment dependant, try it and find out.
Digital Proportional Radio Control nye Electronic Projects Design/Ideas/Reviews 11 21st April 2008 06:07 PM
Radio control of PWM motor speed? gregster Electronic Projects Design/Ideas/Reviews 13 18th February 2007 01:13 PM
Radio control with PIC16F84 jox3000 Electronic Projects Design/Ideas/Reviews 1 27th September 2006 05:13 PM
lithium powered radio control car fingers Electronic Projects Design/Ideas/Reviews 1 2nd March 2005 04:16 PM
Radio remote Control nye Electronic Projects Design/Ideas/Reviews 2 19th November 2004 03:30 PM
