| OK. Got the voltage messurement and it is 2.11 at the TL431. I guess It needs to be exactly 2.5? or could more then 2.5V work? Also does anyone know what the average current needed for a DVD rom laser? That is what I am using and I think 114mA is to high but I could be wrong.... Last edited by silverchris; 29th April 2007 at 12:11 AM. | |
| hi chris, >> It needs to be exactly 2.5? or could more then 2.5V work? The Vref 2.5 is a current limit voltage applied to the base of Q2, the current thru R9 creates a voltage on the emitter of Q2, limiting the current thru the LD. If you start to reduce the Vref 2.5V, then you will have to start altering the value of R9 to compensate. If you increase Vref then then current will have to be greater thru R9,Q2 and the LD before the limiter works. Ref the working current of the DVD/LD I cant help with that query.
__________________ Eric "Good enough is Perfect" PIC tutorials: Gramo's: www.digital-diy.net/ Bill's: www.blueroomelectronics.com/ | |
| ah. I lost my zener for it while working in it so I am trying to work out a way to get a TL431 in there but my spair TL431 seems to be malfunctioning. I have a 2.2K resistor between Cathode and REf and a 1K resistor between Anode and REf so it should be around 8V but I get 6.73V or so | |
| hi, Whats the value of R1, is it still 1K0 ? Measure the voltage at the junction of the cathode and the 2K2??? I think you are limiting the TL431 of current to much from your +12Vsupply.
| hi, As you have a 6V zener, you could use the attached cct for the +8Vs. The RX 1K2 may require 'tweaking' to give an output of +8Vs, if you have a 1K0 pot connect that in series with a 470R. The transistor T1 is a general purpose npn.
__________________ Eric "Good enough is Perfect" PIC tutorials: Gramo's: www.digital-diy.net/ Bill's: www.blueroomelectronics.com/ Last edited by ericgibbs; 7th July 2008 at 12:19 PM. | |
| Thanks. Unfortunately I have to put the project on hold for a few days due to some stuff coming up but I will let you know how it goes. | |
The problem I see with VCC=5.3V is that CR3 (if used) will not allow enough current through the laser diode, even if Q2 were saturated. As mentioned in Sam's explanation, this is intentional. Without CR3, the photodiode can become forward-biased if VCC is low, causing Q1 and Q2 to be a latching positive feedback loop (similar to an SCR), instead of negative feedback as it is when the photo-diode is reverse-biased. I agree that the best solution is to use a TL431 for CR1, programmed to 8.7V. | ||
| Hi Ron, Sorry about delayed response. The CR2 device as I understand from the datasheet will sink 10mA, if its not configured in the programmable mode? The way I see CR2 working is that it acts a base clamp voltage for the LD drive transistor, so that the voltage drop across the 10R shuts off the the driver when the maximum rated current is reached? I cant see a CR3, do we a different drawing? [Ive attached the one Im using] Regards EDIT: attachment.
__________________ Eric "Good enough is Perfect" PIC tutorials: Gramo's: www.digital-diy.net/ Bill's: www.blueroomelectronics.com/ Last edited by ericgibbs; 7th July 2008 at 12:20 PM. | |
| hi Ron, Chris said it was this version,>> Laser Diode Power Supply 1 (RE-LD1) He did say he was busy and would get back to the project shortly. I have re-attached the LD1 Ver1, shortened the file name Just did a test download of file,OK.
| Laser Help! | LiquidOrb24 | General Electronics Chat | 12 | 31st July 2007 10:50 PM |
| laser detection an jumbled reply for speed traps | butchville | Electronic Projects Design/Ideas/Reviews | 33 | 23rd November 2006 08:55 PM |
| holographic 3d display systems | Sim | General Electronics Chat | 20 | 19th July 2004 01:31 PM |
| Laser targeting with photo diodes | Rogue5 | Electronic Projects Design/Ideas/Reviews | 9 | 10th May 2004 01:59 AM |
| laser seeking robot | Syntax | Electronic Projects Design/Ideas/Reviews | 3 | 13th May 2003 04:50 AM |
