| Hi, I'm currently designing the instrumentation for an electric car i.e. ammeter, voltmeter, motor temp indicator etc. I've chosen a PIC to monitor all analogue I/p's and display the results on several 7-seg disp. However, I'm having trouble using multiple lookup tables for the various I/p's. First I thought of checking the analogue ch bits and jumping to the relevant subroutine from there...but it isn't working. I'm using a 16f877A PIC btw. | |
| Your question doesn't make much sense?, try posting your code (use the 'code' tags on the 'go advanced' page to surround the code so it formats properly). | |
| Sorry. Hope this helps make it a little clearer Code: ;The ch0 A/D result is displayed as a 8 bit value
;and subsequently converted to BCD
;Hardware: PICDEMO board.
LIST P=16F877A
ERRORLEVEL -302
include "p16F877A.inc"
TEMP EQU 20h
adif equ 1
adgo equ 2
ch2 equ 6
ch3 equ 7
ADTABLE equ 20
ORG 0x00
goto start
org 0x04
goto service_int ;interrupt vector
org 0x10
start
movlw B'00000000' ;make port b
movwf PORTB ;all outputs
; tris PORTB ; /
BSF STATUS, RP0 ;Bank1
MOVWF TRISB ;PortB as outputs
BCF STATUS, RP0 ;Bank0
call InitializeAD
update
movf ADRES,W
movwf 0 ;save in table
movlw ADTABLE ;chk if ch0
subwf FSR,W ; /
btfss STATUS,Z ;yes then skip
goto NextAd ;else do next channel
movf ADRES,W ;get a/d value
call outputdata ;call correct lookup table
movwf PORTB ;output to port b
NextAd
call NextChannel ;select next channel
call SetupDelay ;set up > = 10uS
bcf ADCON0,adif ;clear flag
bsf ADCON0,adgo ;start new a/d conversion
loop
btfsc ADCON0,adif ;a/d done?
goto update ;yes then update
goto loop ;wait till done
service_int
return ;do not enable int
;InitializeAD, initializes and sets up the A/D hardware.
InitializeAD
bsf STATUS,5 ;select Bank1
movlw B'00000010' ;Vref+ is Vdd, Vref- is Vss, AN0-AN3..
movwf ADCON1 ;analog inputs
bcf STATUS,5 ;select Bank0
movlw B'11000001' ;select:internal RC, ch0, ststus flag off..
movwf ADCON0 ;turn on a/d
movlw ADTABLE ;get top of table address
movwf FSR ;load into indirect reg
clrf ADRES ;clr result reg.
return
;NextChannel, selects the next channel to be sampled in a
;"round-robin" format.
NextChannel
movlw 0x08 ;get channel offset
addwf ADCON0, F ;add to conf. reg
bcf ADCON0,5 ;clear any carry over
;increment pointer to correct a/d result register
clrf TEMP
btfsc ADCON0,3 ;test lsb of chnl select
bsf TEMP,0 ;set if ch1 or ch3
btfsc ADCON0,4 ;test msb bit of chnl select
bsf TEMP,1 ;set if ch0 or ch2
addwf TEMP,W ;add with temp
movwf FSR ;allocate new address
return
;This routine is a software delay of 10uS for the a/d setup.
;At 4Mhz clock, the loop takes 3uS, so initialize TEMp with
;a value of 3 to give 9uS, plus the move etc should result in
;a total time of > 10uS.
SetupDelay
movlw .3
movwf TEMP
SD
decfsz TEMP, F
goto SD
return
outputdata Last edited by Chappie; 25th April 2007 at 03:53 PM. | |
| Simply don't run it in a single loop, read each input in turn, display it as required, then move to the next input and do the same - enclose the complete chain in an overall loop. | |
| And move to an 18F component - much more efficient ........... | |
| Very true but I'm a convert | |
Lefty | ||
| Building an Electric Scooter? | Omar.M | Electronic Projects Design/Ideas/Reviews | 7 | 26th April 2007 06:24 AM |
| Simple question about electric motors | sram | General Electronics Chat | 7 | 12th February 2007 07:49 PM |
| Looking for a Electric Board Repair Company | Slate | General Electronics Chat | 4 | 4th January 2007 03:53 PM |
| Electric fence | zachtheterrible | General Electronics Chat | 6 | 15th June 2005 05:33 PM |
| Electric motor as a generator, DC type? | Johnson777717 | General Electronics Chat | 5 | 23rd June 2004 10:13 PM |
