Sorry to interrupt u all. But i really cannot done it by myself. I'm a univesity student and this this 1 of my assignment to summit by next week. I'm using a op amp to amplify an AC 5V to around 7-8V to drive a 8 ohm speaker. but i juz cann't get it right. I been recommanded to use a IC chips call LM 386 to do the amplification. but the software i use didn't have this IC chips data, and i don't know how to connect it. if anybody know how to solve it, pls reply me n pls show me how to do it. Thanks. Last edited by tuck; 25th April 2007 at 01:02 PM. | |
You don't need an opamp, it can't drive a speaker - you need a power amplifier, of which an LM386 is a small common example.
| | #3 | |
Opamp devices by themselves cannot deliver 7-8V into an 8 Ohm load. | ||
My idea is to set a gain to amplify 5V to 7-8V. so the op amp will act as a power amplifier. The design software i use called Pspice didn't have LM386 this IC chips. N i try to use a normal multistage op amp to set the gain as 100. so the output voltage will suppose to reach around 7-8V which i wanted. but i cannot get it n somehow i got a negative voltage!! Last edited by tuck; 25th April 2007 at 10:48 PM. | |
Do the LM386 perform well, or are there better at a similar price?
__________________ digital-diy.com - Hobby microcontroller projects and tutorials. Assembly, PICBasic and C examples. | |
| | #6 |
The LM386 is for low power, like in a clock radio. With a 6V supply, it clips with only 200mw into an 8 ohm speaker. With a 9V supply it clips with only 450mW into an 8 ohm speaker. With a 12V supply it gets very hot at clipping which is only 530mW into an 8 ohm speaker. An opamp clips with an output power of only 1.5mW into an 8 ohm speaker. You would barely hear it if the speaker is against your ear.
| | #7 | |
The opamp will act as a power amplifier ONLY if it can handle the load. Your negative voltage, is it near the negative power supply? You probably have a wiring error or a simple mistake. It would be helpful for you to post your schematic. | ||
| amplification, map, urgentop |
| amplification dependency on supply voltage | Othello | General Electronics Chat | 4 | 4th January 2007 05:56 AM |
| Please help (voltage amplification) | m_sh84 | General Electronics Chat | 1 | 22nd May 2006 11:08 AM |
| PIR amplification stage | AmirVaziri | Electronic Projects Design/Ideas/Reviews | 1 | 3rd March 2006 03:39 AM |
| Digital Audio Processing and Amplification Project | wilsonmasango | Electronic Projects Design/Ideas/Reviews | 7 | 12th October 2005 05:56 PM |
| audio amplification question & coupling ? | waqar | General Electronics Chat | 0 | 11th April 2003 10:00 AM |
