| Hi all Just a general question here, please help me try understand whats best to do in a situation like this: I am using a 4511 IC to control digits 1-6. My inputs are six individual sing pole switches. Obviously the 4511 IC has 4 inputs, truth table can be found here: Here is a diagram of how I wanted to wire the circuit up... ![]() Problem I can see here is that the inputs are all bridged, so when one switch is closed it will set inputs A,B,C to '1'.... which is not what I want obviously. How do I isolate each switches inputs? Diodes? Resistors? Help please. Thanks | |
| Diodes are usually used for this, you will also need to add a pulldown resistor directly to each input pin including the D input. | |
| like this? ![]() Oh ya, and what do i connect terminal 'D' to if not in use.... just to ground? Or to V+??? (with the resistor of course) | |
| hi ryan, Pin 'D' on the 4511, will go to 0V gnd. Dont forget the /EL, /BI and /LT pins, do you need help on how to connect these? /EL to 0V. /BT and /LT are +V EDIT: The contacts on the 6 switches, which are shown on your drawing, as not connected, will have to go directly to the +V rail. The +Vrail is the supply to the 4511.
__________________ Eric "Good enough is Perfect" PIC tutorials: Gramo's: www.digital-diy.net/ Bill's: www.blueroomelectronics.com/ Last edited by ericgibbs; 25th April 2007 at 07:35 AM. | |
| Are the diodes in the correct place? Its cool, I have a nice diagram for the 4511 which shows all the connections, and I've already wired up the 4511 to the diagram I have, and it works perfectly, I just need help integrating these 6 seperate switches to that circuit... Thanks! | |
| hi, > Are the diodes in the correct place? The diodes look OK. Dont forget the pulldown resistors. If you draw a truth table it will show the logic.
__________________ Eric "Good enough is Perfect" PIC tutorials: Gramo's: www.digital-diy.net/ Bill's: www.blueroomelectronics.com/ | |
__________________ All those who believe in psycho kinesis, raise my hand. | ||
| hi allvol, On his project he is using the diodes as a 'gate' function, so the resistor will have to on the other side of the diode. He his encoding 6 push buttons into a 4511 Regards
| Good Electronic Supply's Sites, Everyone Come On In! :P | Electric Rain | General Electronics Chat | 44 | 28th August 2007 12:06 AM |
| PIC A/D Sampling multiple inputs | NJ Roadmap | Micro Controllers | 10 | 21st February 2007 02:54 AM |
| PIC Switch Management Techniques | Mike, K8LH | Micro Controllers | 2 | 28th September 2006 01:33 PM |
