| Looking for a simple DPDT 12vdc coil relay. Contacts to carry 24 v dc to control a solenoid. | |
Sounds like you only require a standard non-latching relay which is by far the more common flavor Lefty | ||
| Hi all I need some help related to the latching relay... I am using 5VDC single coil latching relay TN-L-5V...I have to control it using a single line of microcontroller...but it needs two pins for set and reset (As mentioned in the above reply; polarity reversal for set/reset) I have to control 20 relays on the PCB, of the size 4x4 inches. If i use a simple inverter for polarity reversal, my PCB size cannot accomodate 4 ICs plus 20 relays. Is there any other option than Inverter? | |
| another problem, which i forgot to mention is, micro controller cannot supply sufficient current to relay. Use of transistor also makes it impossible to develop PCB of size 4x4 | |
| How about you make a double sided board? Micro + Transistors on one side, relays on the other. I realise if you are going to make this manually at home, vias could be an issue - you can just use hook up wire
__________________ What is a joule per second? | |
| Use of transistors is never suitalbe. I told earlier that i am using 20 relays. If i use transistors, for each relay, i will have to use two, and for 20 relays, 40 transistors will be required. vias may not be the problem. Space is the biggest issue. | |
| Is your micro able to sink the current required, rather than source it? That may solve your problem if it is able to. Remember you need diodes as well =P
| Pic type microcontrollers from Microchip can source/sink 20 mA per pin (not all at the same time) that is >= 250ohm relay coil. If you common one connection of all the relays and if you don't have to switch more than one relay at a time, you could take advantage of the tri-state condition of the pins. With couple of transistors, you connect the "relay common" connection to + or - and switch the micro's pin from high impedance to high or low, depending on the operation required. Last edited by Helder Ferreira; 22nd November 2007 at 03:01 PM. | |
| Looking for pre-built 12 volt momentary latching relay | Louis Cypher | General Electronics Chat | 1 | 2nd December 2006 08:31 PM |
| Wiring a latching relay | behrendfry | Electronic Projects Design/Ideas/Reviews | 8 | 4th January 2006 06:00 PM |
| Relay Connections | Johnson777717 | General Electronics Chat | 2 | 7th July 2004 10:45 PM |
| Incubator Relay Circuit | Plip | Electronic Projects Design/Ideas/Reviews | 2 | 26th November 2003 01:36 PM |
| working with a bistabel relais | Monaco | Electronic Projects Design/Ideas/Reviews | 4 | 10th December 2002 07:40 PM |
