| RonSympson wrote: Question: How fast 4 hours 48 minutes? Always the same? The clock is aproximately 4 or more hours off in 24hrs, but i is not dependent on time of day or placement of the clock in a particular room. --------------------------------------------------------------- kchriste Wrote: Which diodes are getting hot? None of them should be. The diodes are not geting hot by running the clock. I meerely heatsink them while soldering as I do every component! --------------------------------------------------------------- JimB Wrote: So, if the 50/60 hz input to pin 25 is faulty in some way, it could be running on the RC oscillator, which could be (and probably is) way off frequency. There may be a problem with the IC but I haven't been connecting the battery backup. --------------------------------------------------------------- AllVol Wrote: That was my question back in the first reply. Diodes seldom need a heat sink (and if they did, where would you buy one?) Must be I did not explain myself well in the first post... heat sinking was to protect the diode for soldering. --------------------------------------------------------------- Bottom Line: Although I have checked solder points, component values, and cleaned the poard with IPA, I will do this again for the hell of it. | |
| When I said the diodes would blow if not heaksinked well I meant that when soldering the components to the board. I heatsink with a pair of hemostats. | |
| I have never heatsinked anything that I have soldered with my temperature controlled soldering iron and nothing has ever been damaged.
| The reason ronsimpson asked about being 4 hours 48 minutes off is: 24 hours X 60/50 = 4.8 hours fast. Pin 27 should have a 900hz signal. That should not effect you problem but it is worth checking. Pin 25 should have 60hz and I would put an o-scope on it looking for a reason why your clock is seeing >60hz. (noise) The data sheet want 100k and .001uf, the kit wants 18k and .01uf. (very interesting) Can you find 100k and .001uf? I think there are two roads to go down: 1) you have 50/60 problems. The error will all wise be the same. 2) pin 25 is seeing noise. The error will be different every day. I am looking for a way of getting another 4 hours in my day. Make you a deal! | |
| Well, cleaned the circuit board with alcohol and a toothbrush. I checked all solder joints for shorts or cold solder points. Still it runs about 4hrs 30min fast in a days time. it doesn't matter what room the clock is in either. The heat sinking of the diodes I had refered to in my original post was during the soldering of the components to the board. | |
| Well, I bought a 28 pin DIP Socket and a new lock IC, hooked it up and it is STILL running fast! Unbelievable... | |
| Problem with LCD code? | spondootre | Micro Controllers | 15 | 29th April 2008 10:15 AM |
| Hardcode a PIC by hand? (or 16F74 + par.port.prog = problem) | smilen | Micro Controllers | 15 | 21st November 2005 10:23 AM |
| Computer CLock Running Fast | bryan | Electronic Projects Design/Ideas/Reviews | 4 | 7th May 2005 06:34 AM |
| Help me on basketball's game clock and shot clock! | syaw_007 | Electronic Projects Design/Ideas/Reviews | 1 | 6th September 2004 10:50 PM |
| Need A Simple Alarm Clock Circuit | Handiplus | Electronic Projects Design/Ideas/Reviews | 0 | 29th March 2004 03:02 PM |
