+ Reply to Thread
Page 3 of 6
First 1 2 3 4 5 6 Last
Results 31 to 45 of 88
Thread: I'm exhausted, and a newb...
  1. #31
    ljcox Good ljcox Good
    Join Date
    Dec 2003
    Location
    Melbourne Australia
    Posts
    2,446
    Here is an extract from the paper I mentioned.
    Len
  2. #32
    philba Good philba Good philba Good
    Join Date
    Mar 2006
    Location
    Seattle
    Posts
    1,887
    I'm not sure what you are disagreeing with. This isn't rocket control, it's just a couple of signals. If you dispute "not worrying about it" then you surely took my comments out of context - ah vs al is not some mysterious thing. that's all I was saying to him.
    But I slightly disagree with your suggestion of an ssi solution (and/nand/on/nor) - 4-16 demux is simpler to wire up and far easier to understand. even if he has to put inverters on the mux outputs. chasing though the terms of your solution is much harder for a newbie to understand. Either one will work but I'm trying to be thoughtful of the OP's experience level.
    By the way, the best way to simplify is to use karnaugh maps to pluck out the relevant terms. but that's well beyond this problem.
  3. #33
    Join Date
    Dec 2003
    Location
    Melbourne Australia
    Posts
    2,446
    Quote Originally Posted by philba
    I'm not sure what you are disagreeing with. This isn't rocket control, it's just a couple of signals. If you dispute "not worrying about it" then you surely took my comments out of context - ah vs al is not some mysterious thing. that's all I was saying to him. What I was trying to say is that the AH/AL concept is very useful.
    But I slightly disagree with your suggestion of an ssi solution (and/nand/on/nor) - 4-16 demux is simpler to wire up and far easier to understand. I agree. If you go back a few posts, you will see that I said that your's is a good solution.
    even if he has to put inverters on the mux outputs. chasing though the terms of your solution is much harder for a newbie to understand. Either one will work but I'm trying to be thoughtful of the OP's experience level. My point is that if he understands my solution, he will then be in a better postion to understand the logic diagram and truth table in the 74HC154 data sheet.
    I used Karnaugh maps to derive the circuit I posted.
    Len
  4. #34
    Franknstein Newbie
    Join Date
    Apr 2007
    Posts
    53
    Just sat this morning sifting through all your replys and spending some time on wikipedia and looking through all your pdf's etc. I am pleased to say I finally understand the concepts. Its actually fairly easy when you break it down, but I am definitely not at a stage where I wont need reference to build anything. Thanks again for all the input/drawings/pdf's and papers, they were extremely useful.
    I will be visiting the electronic supply store tomorrow and will pick up IC's for both yours solutions. I think I will use Philba 4-16 demux chip for the final circuit, but in order to experiment and gain more understanding of how these chips work, I will experiment with ljcox's solution too.
    Next up and am going to interface another circuit I've built with a 4511, and it will need to tell you which gear you are in at the time. As soon as I have the primary gear switching circuit ready then I will do the complete circuit diagram and run it by you guys, I want to see if I can do it by myself.
    Hope to have some results by tuesday.
    laters
    ryan
  5. #35
    Franknstein Newbie
    Join Date
    Apr 2007
    Posts
    53
    Ok, I've finally finished wiring everything up, I built the circuit on a piece of stripboard.
    I tapped into the V+ of the joystick (my meter reads 2.5v from the power of the joystick to the common of all the gear1-6 switches on the joystick board). There is another black wire on the board which has NO continuity to the gear 1-6 common, but when I read the Voltage across that main black wire and the joystick V+ its about 4.5volts.
    I've connected the circuit GND that I built to the 2.5v gear 1-6 switch common.
    I think something I've done is very wrong, because I am getting continuity through every single switch output all the time when the circuit has power (no continuity on any of them when the power is off (this part seems right).
    Please help!
  6. #36
    ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent
    Join Date
    Jan 2007
    Location
    Hampshire. England.
    Posts
    10,836
    Blog Entries
    13
    hi ryan,
    Which version of the circuit are you referring to?
    Any diagrams to post, will help.
    Link to my Articles: http://www.electro-tech-online.com/a...icgibbs-55450/
  7. #37
    Franknstein Newbie
    Join Date
    Apr 2007
    Posts
    53
    Here it is:
    basically, when joystick is unplugged... I get no continuity between the terminals of wire Z and each of the blue wires . this is correct
    when plugged in, there is continuity on all of them (wire Z, and each blue wire)
    this is wrong, as its trying to push all 6 joystick buttons at the same time.
    the red wire is the power supply from the USB, and the black is the USB power GND. When I put a my meter across wires X and Y, I get about 4.5v. When I put my meter across Z and Y, I get 2.5V when none of the S1/S2 etc are active.
    EDIT: there is never any continuity between Z and X
    I think I've wired something incorrectly...
    Help! Please!
  8. #38
    Join Date
    Jan 2007
    Location
    Hampshire. England.
    Posts
    10,836
    Blog Entries
    13
    I havnt been following this post for a couple of days.
    The 74154 is a TTL device, with active low outputs. I thought philba recommended a CMOS version of the device???
    The outputs will be high, around 3 to 4 volts when none of the S1 thru S5 push buttons are pressed.
    To set '5' low,[1st] both S1 and S3 must be pressed.
    I'm sorry this help is limited, I'll look thru the back posts and try to get up to speed.
    EDIT: I assume that you have got the +5V and 0V lines connected to the 74154?
    I have got to ask, just in case!
  9. #39
    Franknstein Newbie
    Join Date
    Apr 2007
    Posts
    53
    Hi Eric
    I am using the 74HC154. Which is CMOS right? Sorry, I just used philba's attached diagram which had 74154 as the label from the beginning.
    The V+ and V- are connected, forgot to add that to my diagram, V+ is common with red wire on my new diagram and V- is common with wire 'z' on my new diagram.
    please check the above diagram again, I have updated it with the Vcc and GND connected, and the full name of the chip.
    tnx
  10. #40
    Join Date
    Jan 2007
    Location
    Hampshire. England.
    Posts
    10,836
    Blog Entries
    13
    hi ryan,
    Understood.
    Looking back at your earlier posting.
    The Common of the S1 to S6 should be at 0V [Gnd], not 2.5V
    This Black wire is the 0V [Gnd] and should be connected to the 0V of your pcb, pin 14 of the 74HC154 and the S1 to S6 Common.
    Recapping:
    The RED wire +V should goto the top of the resistors, as you have shown and pin 24 of the 74HC154.
    The BLACK wire 0V should goto the Common of S1 thru S6 and pin14 of the 74HC154.
    Dont use your meter on Continuity to test the circuit when the ic's are connected.
    Remember when you have connected as described, the output pins of the 74HC154 without any gear switches pressed will be high, about +4V.
    The selected output will goto 0V when the correct gear switch is pressed.
  11. #41
    Franknstein Newbie
    Join Date
    Apr 2007
    Posts
    53
    Thanks Eric.
    Like this: ?
    notice common of now named switches y1-y6 (S1-S6 were confusing me as they share the same name as S1,S2,S3,S5 to the left of my diagram) is not connected to anything anymore, its just as it was on the USB joystick board from the factory, and does not share continuity with my 0V GND wire.
    Is that correct now? I want to be sure, before I do something wrong and blow something up
    Also, whats wrong with using the meter btw?
    tnx again
  12. #42
    Join Date
    Jan 2007
    Location
    Hampshire. England.
    Posts
    10,836
    Blog Entries
    13
    That looks OK to me.
    When its connected up and plugged in check the voltages with your meter.
    Lets know what they are.
    The problem with testing for continuity with ic's connected is that some meters when on the 'ohms' resistance range can have a voltage on the leads due to the meters internal battery. Depending on the type of meter it may apply a 'reverse' voltage on the ic's. Also you will get misleading readings caused by pathways thru the ic's.
  13. #43
    Franknstein Newbie
    Join Date
    Apr 2007
    Posts
    53
    Ok, plugged in and put on the joystick test utility again, now it seems a bit better, when powered up, none of the joystick buttons are on... But selecting any combination of S1,S2,S3,S5, will also not yield any change.
    Point of interest: If I just touch wire 'z' to wire 'x' (this was a last resort test), all six of the buttons y1-y6 become active.
    One thing I dont understand about this circuit is that wire 'x' and wire 'z' are not common, so how can it complete the circuit ever, unless I wire them together (which makes all six permanently on)
    Getting 5V between y1-y6 and X when all of switches S1,S2,S3,S5 are open
    Getting 1v between y1-y6 and Z when all of switches S1,S2,S3,S5 are open
    I get the same 5v when I try activate y1, this is on wire X
    I get .5v when I try activate y1 (so it drops .5v), this is on wire Z
  14. #44
    Join Date
    Mar 2006
    Location
    Seattle
    Posts
    1,887
    to start with, disconnect the output of the '154 from the joystick. then measure the voltage from each of the outputs as you run through the switch combinations. (i.e., select 1st gear and then check the voltage on all 16 outputs). They should all be high except for one. If that's not right, then check to see that the inputs to the 154 do the right thing as you run through the gear selections.
    just a thought, you didn't wire the chip backwards? It's a surprisingly easy thing to do. even for old timers...
    something that was discussed but I wasn't quite clear on, does your joystick want active high or low inputs? I would guess low but you will need to verify that.
  15. #45
    Franknstein Newbie
    Join Date
    Apr 2007
    Posts
    53
    I haven't disconnected and tested the outputs of the '154 yet, will do that a little later.
    I'm pretty sure the chip is in the correct way, I soldered on a chip holder too. The actual chip has a full circle on the bottom, and a semi-cicle indent on the top, the datasheet shows just the semi-circle on the top, so thats how I did it...
    Not too sure what inputs the joystick requires. I thought you guys said it was CMOS, so it had to be active low. Nonetheless, if i diconnect my newly built cicuit enirely from the joystick and take a jumper and bridge wire Z to terminal y1, it activates that button, without any external voltage whatsover.
    Thats what I didn't really understand about this whole circuit. I thought we could just close each switch remotely, instead of introducing voltage from an alternate circuit.
    I'm very confused now!
    EDIT:
    Tested the inputs, they work perfectly, chip is wired fine aswell.
    The outputs: Seem to be great aswell, I get a mutually exclusive Low output for each corresponding gear. ie (y1 is high 5v+ in all possible gear combinations including neutral, except for 1st gear.) This is using wire y as the anode on the multimeter.
    This seems like a good thing, the circuit seems to work perfectly, except its not activating the gears on the joystick.
    Im am so sure that it has something to do with the fact that wire 'Z' on my latest diagram does not have continuity at all with 0V gnd, whereas that is the common opposite terminal for all the joystick buttons y1-y6.
+ Reply to Thread
Page 3 of 6
Tags for this Thread
