| I have built a capacitive discharge system for my electronic firing system and I have (9) 200vdc 220uf capacitors that charge up from the power supply. I am needing to use a resister to slowly drain the capacitors once power is turned off. I am using Dale aluminum RH-560 50W 1.5 ohm on my power supply to generate the 200vdc power load. I would like to use (1) resister to slowly drain all (9) separate power lines, these are individual power lines but I would like to slowly drain all of them with one resister. What do you recommend, and do you have a diagram that can be put to use? | |
| The caps probably won't care about discharge rate. Old rounded-off screwdrivers used to do the trick real well, although they would occasionally weld onto terminals. If you want to use a switch and have it last, grab a 10 watt 1000 ohm sand resistor and switch it across the caps. Just leave it connected for 10 minutes and all charge will be gone. | |
This is a High Voltage power supply for fireworks discharge and I need something to be internal I would not rather us a switch. Can this be left on permanetly, Not the screwdriver done that, I would like to design it on my board so the power supply works as normal but when I turn off power to the supply the cap will drain and not leave high voltage on the board. Last edited by hfireworks; 16th April 2007 at 02:16 AM. | ||
__________________ --- The days of the digital watch are numbered. --- | ||
Bleeder resistor is what I am looking for and the discharge time is not relevant as long as it does discharge slowly. | ||
| I would use a 1/2watt 150K
| hi, You could use a suitably rated domestic mains filament lamp as a load dump. In the UK, most domestic lamps are rated at 240Vac, if you chose say, a 25Watt version, this would drain the caps to zero quickly and safely.
__________________ Eric "Good enough is Perfect" PIC tutorials: Gramo's: www.digital-diy.net/ Bill's: www.blueroomelectronics.com/ | |
I do not want the voltage to drop very quickly, as to be a drain on my main 24vdc batteries to keep the capacitors in full charge during operation. Last edited by hfireworks; 16th April 2007 at 08:31 AM. | ||
| hi, There are 'pygmy' versions of the lamps down to 15Watts and less, in different colours. Low energy types, if suitable, as low as 3Watts.
__________________ Eric "Good enough is Perfect" PIC tutorials: Gramo's: www.digital-diy.net/ Bill's: www.blueroomelectronics.com/ Last edited by ericgibbs; 16th April 2007 at 08:43 AM. | |
If all the 9 capacitors have a common negative connection, then it might be possible to connect up all positive terminal of the capacitors to a common point using blocking diodes and discharge all 9 capacitors with a single resistor.
__________________ L.Chung | ||
| Use some 250V mosfets with bleed resistors in drain. One button press (tied to all the gates) could turn them all on and discharge each C with its own resistor. BTW, you do not need high watt ratings for the discharge resistors in this case because they are not always in circuit dissipating power. They only switch in when you signal to discharge. | |
So typically using the 9 blocking diodes to prevent backflow from the 9 Capacitors I can connect all 9 capacitors to a block and using a single switch to discharge all 9 capacitors into a single resistor. So, if I switched all 9 capacitors into a single resistor, I would have 9 200vdc 220uf caps. Would one Dale RH-50 50watt 1.5k aluminum resistor handle that kind of power to drain? If that were the case I could add a swich, possibly a high power SCR, or Darlington Pair or a relay to a toggle and add an LED and discharge. Last edited by hfireworks; 16th April 2007 at 02:44 PM. | ||
I havn't used mosfets yet but read a little on them, I am beginning to se the bigger picture on this now, The design is popping into my head. Since the capacitors have an abundance of power stored, could connecting all 9 of them create a surge on the resister? | ||
I am curious as to the 10 watt 1000 ohm sand resistor I have not seen one, what are the characteristics of these? | ||
| Power supply consumption | Electronics4you | General Electronics Chat | 3 | 14th March 2007 08:19 PM |
| 24v DC Power Supply (Help & Information Wanted Urgently) | ampthetex | Electronic Projects Design/Ideas/Reviews | 5 | 17th November 2006 01:45 PM |
| Power Supply Failure | Joel Rainville | General Electronics Chat | 8 | 24th August 2005 02:42 PM |
| need help with power supply parts very info... | rodniepr | General Electronics Chat | 0 | 6th April 2005 04:33 AM |
| PC Power Supply Problems | brentonw2004 | Electronic Projects Design/Ideas/Reviews | 3 | 29th March 2005 12:01 PM |
