| I'm having trouble with a 4017 IC. I have it wired up as follows: Relay to debouncer (http://www.elexp.com/t_bounc.htm - Figure 2) -R = 1M ohm -C = 0.1 uF -Relay completing the circuit to ground for the switch -Using a 4011 IC with inputs tied together to make a NOR gate -I calculated this to give a 0.1 second debounce time NOR gate to Clock on 4017 Output to LED's having common cathode (vertical stripe on breadboard) common cathode strip to resistor (470 ohm) 470 ohm Resistor to ground Everything is powered from a single 12V 5AH Lead Acid battery The issue I'm having is that it transitions as 2 pulses when i trigger the relay. If I trigger the relay within a very short time frame after it is released it will pulse as 1 cycle, advancing by 1 led. If I wait more than roughly 1-2 seconds it will advance by 2. Any ideas on the issue? Thanks, danuke | |
| hi danuke, A better choice of for the ic would be a 4093 quad dual input NAND schmitt. They are pin compatable with 4011. The RC filter has a slow risetime, so the output of the 4011 will oscillate as the risetime voltage passes thru the 4011 input transition/switching value. The 4093 has a schmitt input which will prevent this oscillation. Post a diagram of the circuit. Check the maximum output current from a 4017's output pin?
__________________ Eric "Good enough is Perfect" PIC tutorials: Gramo's: www.digital-diy.net/ Bill's: www.blueroomelectronics.com/ Last edited by ericgibbs; 14th April 2007 at 04:21 PM. | |
| I take it you're not using the other gates for anything. You can build a schmitt inverter with three NANDs.
| 555 & 4017 | mozikluv | Electronic Projects Design/Ideas/Reviews | 14 | 16th June 2008 06:08 AM |
| cascade 3 4017 counters | purcer | Electronic Projects Design/Ideas/Reviews | 23 | 19th January 2008 01:27 PM |
| 16-step sequencer from two 4017 decade counters? | october71 | Electronic Projects Design/Ideas/Reviews | 12 | 29th January 2004 10:11 AM |
| Music Effects with 4017 and 555 | afs87 | Electronic Projects Design/Ideas/Reviews | 5 | 20th June 2003 06:21 PM |
| Working with the 4017 | fantasymick | General Electronics Chat | 3 | 18th May 2003 05:41 AM |
