| Well for the D/A i am using a R2R ladder with R=10k . As far as the OR gate i am using a SN7432N, is that ok ? I think the guess by the d/A is off because its not taking into account the other 4 bits. pete | |
As I mentioned in a previous post, you will need either a commercially available R2R ladder, or 0.25% (or better) resistors if you make it from discrete resistors. Otherwise, it will be nonmonotonic. Also, the ON resistance of the Q outputs is about 200 ohms typical, 350 ohms max. This resistance adds to the value of the 2R resistors in your ladder, which causes additional error. The unused bits will only cause quantization error, which for 8 bits is 5V/2^8, or about 20mV. | ||
| So what exactly in the schematic is the function of the OR gate in this application ? Pete | |
| | (permalink) | ||
I looked at the truth table to try to understand this, but I still don't. It looks to me like you would need a minus OR (AND) for this function. If no one else here explains why it is an OR on the datasheet, you might want to try a 74HC08 or a CD4081 (quad 2-input AND gates). These have logic levels compatible with your SAR. | |||
| I will try using the AND gate later on today, thanks for the suggestion...I will let you know of any observations.. The way i have it running now is by connecting the /cc to /s, what negative effects would that have ? Thanks for all your help by the way Ron. pete | |
| I was just re asking differently because its sometimes hard to decipher spec sheets. Anyways, first i tried replacing the 7432 IC with another to make sure the same thing would happen and indeed it did. I then proceeded to place a pull up resistor on the output of the OR gate and that really didn't change much. My next change was to replace the OR gate with an AND gate specifically an 7408 IC. Interestingly this actually yielded some decent results, At zero input volts the serial out yielded a straight line at level zero while turning the pot yielded various waves. To further test things i also replaced the resistors with more accurate metal oxide type ones and the results where pretty decent and improved. One slight issue is the highest analog input voltage its willing to display digitally is 4.35V . Anything more than that and it just goes all HIGH. Not sure whats the deal with that. THanks pete Last edited by amdkicksass; 7th July 2007 at 08:36 AM. | |
| Any new ideas on the low voltage thing ? Also RON if you can possibly help me out with the circuit to replace the LM311, i would highly appreciate it. Thanks pete | |
Sit down before you look at the comparator schematic. This works well in simulation. Offset voltage can be a problem with discrete transistor comparators. You can either live with it, or you can match them in pairs - Q1 and Q2, Q12 and Q13. You should use 1% resistors for R5 and R6. Last edited by Roff; 10th July 2007 at 05:43 AM. | ||
| I have verified the circuit and indeed all 8 bits are connected correctly. Pin 7 (Q3) goes to the and gate and not 18. I have made some voltage measurments, maybe they can aid in some speculation of the problem. Analog IN ... D/A Out AND Gate ... D/A Out Direct /S to /CC .20 ...... .61 ..... .46 1.26 ..... 1.26 ..... 1.25 2.0 ..... 2.01 ..... 2.04 2.5 ...... 2.23 ..... 2.3 3.5 ...... 3.69 ..... 3.68 4.25 ...... 4.11 ..... 4.17 5 ..... 4.39 ..... 4.56 +5Volt Regulator OUT : 5.00 volts -5Volt Out : -4.78 volts +12volts Supply: 11.93 volts Anything look odd ? Ideas ... pete | |
| Do you have plenty of power supply decoupling caps, and good ground planes? You should have, at minimum, a 100nF cap from each supply pin to GND on each IC (or circuit, when you go discrete). The fact that you get different answers with and without the AND gate implies to me that you need better decoupling and/or a pullup on your AND gate output (or a CMOS AND gate). Re-read my comments about logic levels. Your LSB is only 20mV. Digital noise can easily be 10 times this. It is best to have separate analog and digital ground planes, with them connected to each other at one point only. I don't think this will work in the case where you are using the SAR outputs as the switches for the ladder network. Since you are also using +5V for analog and digital purposes, you need to be sure that +5V is extremely clean (well-filtered/decoupled). It is the reference for your A/D and for your D/A. From a noise standpoint, it would be better to have a separate analog +5V, with a D/A which does not use the outputs of the SAR as the switches for the ladder network, because the SAR puts a lot of undesirable current transients on the +5V supply. | |
| Hey Roff i got around to building the circuit and something isnt working right. Input transistor one gets very warm and regardless of the input state the output is 5 volts ? Any ideas where i can look to fix the problem ? Thanks pete | |
| What type of transistors did you use? Did you make any assumptions about the pinouts on them? | |
| You wont believe the stupid mistake i made ....lol I assumed that the transistors are the common EBC pin variety so when i connected it all together nothing worked. Yesterday night it hit me to check everything and look at the data sheets and then i realized they aren't the normal pinout but rather BEC. I will try that today.. Can u please explain the purpose of the diodes ? Also in brief the purpose of the different stages...I recognize the first stage as being a diff amp... Thanks pete | |
| | (permalink) | ||
Overdrive recovery time is a function of the current available to charge and discharge the capacitance of a node, and the voltage over which that node must move before switching occurs. EDIT: Below is an annotated schematic. Last edited by Roff; 29th August 2007 at 12:14 AM. | |||
| The Oscilloscope | ElectroMaster | Electronic Theory | 12 | 3rd February 2008 02:45 PM |
| analog to digital converter | victorcarlos | Electronic Projects Design/Ideas/Reviews | 8 | 16th March 2007 03:23 AM |
| Digital to Analog Converter? | arrow | General Electronics Chat | 8 | 10th December 2006 10:11 AM |
| Analog to digital converter | pasawphaw | Robotics Chat | 14 | 1st December 2006 04:40 AM |
| Analog digital converter.. vise versa... | sonaiko | General Electronics Chat | 7 | 10th November 2004 12:42 PM |
