Old 10th April 2007, 02:40 AM   #1
Default High voltage lifter
i am planning to build a high voltage lifter and was wondering what kind of voltage would be necessary to make it work. i do have some ways of making high voltage eg; igniton coil and driver, super mini tesla coil.
which one of these would suit best if i had to use them
thanks
things is offline
Old 10th April 2007, 09:03 AM   #2
What voltage levels do want to produce, is it AC/DC and at what current.
Whats the HV going to be used for.?
ericgibbs is offline
Old 10th April 2007, 11:48 AM   #3
apparently if you hook up high voltage to a peice of wire over some aluminium foil under it it wil creat some kind of ionic wind and will lift it.i've seen some use neon sign transformers for the high voltage but i don't have one . so i was wondering if an ignition coil will be able to supply a high enough voltage eg;it can generate a 1cm spark
things is offline
Old 10th April 2007, 02:25 PM   #4
An ignition coil will easily generate 10kVolts, a rule of thumb, a 10kV voltage will jump across a 1cm gap.
When you use the ignition coil dont forget the series ballast resistor.
Old 11th April 2007, 09:55 PM   #5
I thought neon sign transformers were current limited.
A neon sign transformer will produce AC, you want DC so so you'll need to put it though a rectifier and small filtering capacitor. If you want it to be safe then you'll probably need to limit the current; this is why you might want to consider a ballast resistor.
if I know the answer.
Hero999 is offline
Old 12th April 2007, 08:02 AM   #6
the reason i wan't to use an ignition coil is because i already have a jacobs ladder kit that uses one so the swithing is all ready done for me and it only the high voltage generator i have apart from some tiny tiny tesla coil things (from a plasma ball) and a peizo lighter.
things is offline
Old 21st April 2007, 11:13 AM   #7
All i was wondering is what kind of voltage is required to lift the thing, i have made one and get some wind but do i need more voltage or wire closer to the foil.
thanks
things is offline
Old 21st April 2007, 02:28 PM   #8
Find a copy of "Electronic Gadgets For The Evil Genius", first project in the book.
They use 30 kVDC, the voltage is connected to the foil. Not sure if the DC matters or if it's just the driver circuit they want to sell you. Seems it works the same way an Ion-motor works with a Tesla coil, which is AC. Almost tempted to dust off my 250kv Tesla and try it, but don't want to risk killing this computer. Not 100% it was responsable, but haven't had any hardware failures since putting it away...
HarveyH42 is offline
Old 24th April 2007, 12:07 PM   #9
i have been looking around for tesla coils as i really want one but cannot build one due to time and price. the cheapest one i could find was a kit for $500. going to be saving for a while
things is offline
high, lifter, voltage
Simple High Voltage Question grrr_arrghh General Electronics Chat 18 12th August 2007 11:05 PM
Voltage ElectroMaster Electronic Theory 44 8th August 2007 06:35 PM
Introduction to High Brightness LEDs and Thermal Management Ocelaris Electronic Projects Design/Ideas/Reviews 3 17th March 2007 06:35 AM
High voltage transformers Wrighty General Electronics Chat 3 24th March 2005 04:53 PM
Need to raise low voltage to logic high roffee Electronic Projects Design/Ideas/Reviews 1 25th February 2004 03:43 AM
