| Experienced Member | Can't find any info, so decided to ask: I have battery powered device that needs 80mA @5V and 120mA 3.3V I am planning to use 4 AA batteries that gives me about 6V if fresh. Device will be powered for about 10 minutes at the time so I expect relatively long batttery life. I can easily get 3.3V from 5V (7833), but what will be easiest and cheap way to get stable 5V +0.2V/-0.5V from the battery. Any special ICs or circuit designs? Also I would like to have reverse polarity protection. I understand that getting 3.3V from 5 using linear regulator is not the best way, so I may need to generate 3.3V from battery directly. 5V side used for PIC18F and LCD display. Thanks |
| Experienced Member | One thing I'd encourage is that you understand the lower limits of voltage from the AA cells - the point at which you might consider changing them. I don't know what that is - but let's say it's 1.25 volts per cell. That suggest you have no headroom for a linear regulator - leaving a switching regulator as a possible solution. If by some chance the lower limit per cell was 1.5 volts that leaves 1 volt - possibly enough for a low dropout regulator however that seems awfully close.
__________________ stevez |
| Experienced Member | Quote:
Technically I want to have 2 switchng regulators that can give me 5V and 3.3V with minimum energy loss and ability to work with low voltage AA cells. I just thought someone can recomend regulators that specifically designed for battery circuits | |
| Experienced Member | Use a low dropout regulator for the 5V supply, you also might want to consider using a switching regulator for the 3.3V supply. There are ICs around that will do what you want, check Maxim's and Linear's websites. You can build also it from descrete components but it won't be as straight forward, I can post some links and schmatics if you like. |
| Experienced Member | Since I posted this question I realized that I should use switching regulators with boost-up to minimize energy loss I will try TPS60121 for 3.3V and TPS60140 for 5V In this case I can use only 2 AA cells I actually know my requiremens much closer now: 3.3V @ 160mA 5V @ 40mA 5V may go down to 3mA if I will eliminate LCD backlight and one LED |
| Battery charger cum active circuit driver | yagtoby | Electronic Projects Design/Ideas/Reviews | 0 | 27th September 2006 02:41 PM |
| Questions about battery powered device | ptewright | General Electronics Chat | 1 | 3rd February 2006 04:29 AM |
| Battery Charging Circuit? | 2camjohn | General Electronics Chat | 12 | 3rd May 2004 06:36 PM |
| Charging circuit for my camera external battery pack | Wuey | General Electronics Chat | 7 | 2nd May 2004 10:08 AM |
| battery powered single speaker amp | erastos | Electronic Projects Design/Ideas/Reviews | 7 | 8th August 2003 02:16 AM |
